- First Name
- Terry
- Apr 27, 2021
- West Chicago, IL
- 2024 Edge SEL, 2024 Lariat Tremor
- Engine
- 2.0L EcoBoost
After seeing the under-engine deflector on both my '18 Escape and '19 Edge, I've retired from doing my own oil changes.With 8.6" of ground clearance, I'm sure I could slide under for the filter swap, same as with my Ram.
Hopefully they don't use a under body air deflector with no ports on it like the Escape. Every time you change the oil you have to remove like ten fasteners under the vehicle. Makes you wonder if someone sells a filter relocation kit, or failing that modify the air deflector to cut a hole in it by the filter that you can just cover and uncover quickly.
HRG
