Administrator
Administrator
Staff member
MTC
Fords
The Lariat (without Luxury Package) features two bed cubby holes. Otherwise, the driver's side bed cubby is replaced with the bed light and inverter socket (per @Darnon)
The XLT adds passenger side bed side storage (per @mamboman777)
The XL does not feature a cubby.
Updated with info / photo on Lariat with Luxury Package, by @JJC :
Lariat Lux only has passenger storage compartment. The driver side has the light and plug, no compartment.
Lariat Lux driver side bed pictured below:
Ford Maverick Video: Maverick Lariat Carrying Small Motorcycle & Bed Side Storage Cubby First Look {filename}
mamboman777
Josh
NRH, TX
Says Lariat on the badge and in title.
I read that before posting. I will be more specific. Does XLT and XL get cubbies in both sides?
abcinv
Tommy
NW Georgia
'22 Maverick Hybrid XLT / '06 Tundra dbl cab 4x4 Limited
Just Lariat if my memory serves me correctly. Others come with one on the passenger side...
Specifically Lariat without the Luxury package otherwise the driver's side is replaced with the bed light and inverter socket.
mamboman777
Josh
NRH, TX
Thank you. I wonder what will be there in my non-LUX XLT. Just a panel? Metal? 🤔
mamboman777
Josh
NRH, TX
I found the product guide. Looks like XLT adds passenger side bed side storage. That tells me XL probably doesn't have it. The document I found makes no mention of drivers side on XL, XLT, nor Lariat. I know that's the place where the light/inverter panel goes, but I've never seen storage there until today, which is why I asked.
medgar
SC
Honda Civic
Ive read in a few places that XL has the space it just doesnt come with plastic cubby. Will need to unbolt panel and insert cubby after market
JsnMrd
2016 Honda Civic Touring
So on the Lariat, where does the bed light and power outlet located if the second cubby takes its place?
Stimpy433
Chad
Iowa
2022 Mavrick
You only get the bed light and power outlet if you get the luxury package, otherwise you just get the two cubby storage compartments.
  • Like
Reactions: JJC
Scupking
CT
2025 Ford Maverick XLT Hybrid
Yup I heard the same. Should be easy to add it afterwards to the xl. I plan to.
MavrickEcoBoost
2019 Ranger
Lariat Lux gets both, two compartments and the light and plug. At least that's what the build sheet shows. It'll be interesting to see how they put it all together.
MavrickEcoBoost
2019 Ranger
Well if you look at the build sheet on the forum, it shows the Cubby on both sides as standard. Then when you add on the Lux it add on the plug and light. And the sheet doesn't say you lose the left cubby by getting the lux. I think the issue is we are looking at all preproduction models. Wont know until it comes out. Im perfectly fine to lose the left to have the plug and light.
