Status
Not open for further replies.
rlhdweman
Dan
Random Lake Wisconsin
Top speed is what I meant. Does it have tall enough gears to go 120 or 130mph or more
According the gear ratio/speed calculator, if you can get it to 5500rpms in 8th gear with the 3.81 final drive ratio, you would hit 197mph, no amount of power is going to do that, but I am sure that 130 is doable with a tune & limiter removed. 6th gear would give you 122mph
dalola
Retired
SE Ohio 🇺🇸
Gears will not be an issue. In stock configuration, HP and aerodynamics will start to play a larger role at those speeds.
kkreit01
Korey
Olathe, KS
'22 Maverick, '17 Grand Cherokee Limited 4x4 V6
I'm sure it could easily. My '21 Edge with the 2.0 EB, 8 spd, 3.80 gear ratio was governed at 122. It got up there easily.
Dueces
The Maverick with the limiter removed will do well over 138.5mph, with supporting mods and tune.....
That's what I hear anyway.... 😁
Ivan, hurry up and get those mods on!
Olikestrains
Owen
Denver
2023 maverick ordered
Anyone know how long the trans will last at these high hp numbers?
MavDave
Houston
2022 XLT
Long enough for those who want the speed to find a way to get it... "reliably" or at least not skeered to kill it every time they turn the key. Unless you tune out the torque limiting to the trans. I would expect that it will go for quite a while.
Hardening2753
Ford Maverick Hybrid
With a Livernois E30 tune. Otherwise the truck’s completely stock. I sold my 12 second 2022 XLT to a good friend when my 23 Lariat AWD BAP arrived. Ran a 14.6 completely stock, 14.1 with a 91 octane tune and 13.98 with the E30 tune. This truck is so much faster than my old one it’s crazy. Now that I have the baseline down, the pile of parts I have will start going on.
Next is :
S&B intake
3 inch downpipe
Intercooler and hard pipes
Corsair Turbo
Then the fuel system upgrade Liveronis is developing for full E85. They will also release an upgrade to their tuner that will feature on the fly tune selection and launch control!
This year I have my sights set on an 11 second pass if the trans doesn’t have other plans lol
Do you commute with this too or just race days
rlhdweman
Dan
We will probably know within a year & it will be longer than we thought.
Status
