FERALMAVERICK
Brent
2025 maverick tremor
Now that I have everyone's attention. The ford performance intercooler does NOT fit , not a bolt on . But it does actually fit and with some modification, trimming and large ties it fits and clears the approach angle lower fascia of the tremor with have to trim or cut it . The radiator and intercooler are tremor specific everything is smaller and or recessed on it to fit back about 1-1.5 inches and the passenger side up hanger is in a different location it's mounted outward. The lower bracket/pinch clips are perfect other then there about and inch to short to push threw the intercooler the upper driver hanger/mount is the same . But you can run a zip tie threw the middle of the lowers amd the intercooler and pull it snug . I used 1/2" wide reinforced ties (2 on each lower) and it's solidly stable the pipes line up and lock on correctly . Onto the shutter u need to remove it mainly just the hinges and blades I squared up the opening and still maintained all the weather stripping and baffles so when the bumper was reinstalled it looked and fit like OE . Sry I didn't take as many pic as I intended to as I went. Especially since I was hoping for a little more plug and play on the hanger/mounting side . Buts it's not horrible to do and can be done . Just take your time
Ford Maverick Ford Performance Intercooler installed on 2025 Maverick Tremor 20260612_104809
Ford Maverick Ford Performance Intercooler installed on 2025 Maverick Tremor 20260612_104807
Ford Maverick Ford Performance Intercooler installed on 2025 Maverick Tremor 20260612_111453
Ford Maverick Ford Performance Intercooler installed on 2025 Maverick Tremor 20260612_091159
Ford Maverick Ford Performance Intercooler installed on 2025 Maverick Tremor 20260612_091142
Ford Maverick Ford Performance Intercooler installed on 2025 Maverick Tremor 20260612_111456
Ford Maverick Ford Performance Intercooler installed on 2025 Maverick Tremor 20260612_111500
Ford Maverick Ford Performance Intercooler installed on 2025 Maverick Tremor 20260612_111504
Ford Maverick Ford Performance Intercooler installed on 2025 Maverick Tremor 20260618_134637
Ford Maverick Ford Performance Intercooler installed on 2025 Maverick Tremor 20260618_134647
Ford Maverick Ford Performance Intercooler installed on 2025 Maverick Tremor 20260618_134628
Ford Maverick Ford Performance Intercooler installed on 2025 Maverick Tremor 20260618_182643
Ford Maverick Ford Performance Intercooler installed on 2025 Maverick Tremor 20260618_182658
Ford Maverick Ford Performance Intercooler installed on 2025 Maverick Tremor 20260618_182719
Ford Maverick Ford Performance Intercooler installed on 2025 Maverick Tremor 20260618_182723
Ford Maverick Ford Performance Intercooler installed on 2025 Maverick Tremor 20260618_182706
BK007
BK007
OH
Appreciate the write-up! That is a hell of a lot of work! Curious though—what are you seeing for real-world gains with just the cooler upgrade? Are you running a tune to take advantage of it, or are you still on the stock software/turbo setup? 🤷‍♂️
FERALMAVERICK
FERALMAVERICK
Brent
IVE ONLY DRIVEN IT 2 DAYS SO FAR , THERE IS DEFENITLY DRIVING DIFFERANCE @ SPEED . IM CURRENTLY RUNNING THERMAL CAT BACK , GFB BLOWOFF VALVE AND A DROP IN FLITER ( WAITING FRO SB FILTERS 25+ COLD AIR) I WOULD LOVE TO GET A TUNER TO REALLY OPEN IT UP ( OR THE 300T TURBO AND FLASH TOOL ) AND IF SOMEONE MAKES A 3" DOWNPIPE . ALL THE THE ECOBOOST MOTORS ARE UNDER COOLED AND I PLAN ON KEEPING THIS FOR THE LONG HAUL . SO SOME OF THIS WAS FOR THE ACTULLY COOLING AND GET REDUCE THE HEAT SOAK IN THE TURBO .
Cancunbadlands
Cancun
Cancun
Great upgrade! Now we're talking!
BK007
BK007
OH
Nice job on the install. Definitely keep us updated on your build and what you end up doing—would love to see some pics of the final engine bay layout when you get a chance!
Cancunbadlands
Cancun
Cancun
IVE ONLY DRIVEN IT 2 DAYS SO FAR , THERE IS DEFENITLY DRIVING DIFFERANCE @ SPEED . IM CURRENTLY RUNNING THERMAL CAT BACK , GFB BLOWOFF VALVE AND A DROP I⁴N FLITER ( WAITING FRO SB FILTERS 25+ COLD AIR) I WOULD LOVE TO GET A TUNER TO REALLY OPEN IT UP ( OR THE 300T TURBO AND FLASH TOOL ) AND IF SOMEONE MAKES A 3" DOWNPIPE . ALL THE THE ECOBOOST MOTORS ARE UNDER COOLED AND I PLAN ON KEEPING THIS FOR THE LONG HAUL . SO SOME OF THIS WAS FOR THE ACTULLY COOLING AND GET REDUCE THE HEAT SOAK IN THE TURBO .
Thermal catback sound clip?
FERALMAVERICK
FERALMAVERICK
Brent
THANK YOU , I WILL UPDATE ON THIS AND HOPEFULLY GET MORE GOODIES SOON
Marty
2026 Ford Maverick Tremor
Cancunbadlands
Cancun
Cancun
Platinum2
MI
Ford
I threw out the factory Intercooler the third day after buying my Maverick. A good upgrade to minimize the likelihood of timing being pulled due to high intake temps.
