Wrong Battery Coding from the Factory?
EONR24
Swag
United States
2024 Ford Maverick XL
I have not tested this coding below or changed battery target state of charge in forscan yet because I have not had any battery issues on my 2024 yet. "knock on wood" But I came across this coding in the BCM that just doesn't seem correct. It is the same for all Ford Mavericks..
The factory coding for the digit below is F for every Maverick made... But F indicates BC AGM which I think means "AGM Battery Configure" when I believe it should be E which indicates BCM FLD meaning "Flooded Battery Configure"...
Ford Maverick Wrong Battery Coding from the Factory? Screenshot 2024-04-17 at 2.16.11 PM
EONR24
EONR24
Swag
United States
Would this be beneficial to change for some owners or no?
EONR24
EONR24
Swag
United States
I guess Ill go pop my hood and see if I can tell what type of battery mine has by a part number lol
EONR24
EONR24
Swag
United States
Configured as a BC AGM. Im assuming its Flooded but Id like to go check and make sure.
inline_five
2023 Hybrid XLT
My 22 hybrid keeps the 12v about 60%.
Annoying, but the truck starts every day as the hybrids don't need cranking amps. Just 12 volts to feed the computers.
It's actually bad. Really bad for lead acid 12v's to sit at that level of charge. They really like 90%+. It extends their life significantly.
Ozarkbeard
This☝
Battery lifetime is why I pulled Fuse 11 and use a battery maintainer, when not driving for a few days. I use a maintainer on other lead acid batteries, too. It extends the battery lifetime considerably, at least in my experience, anyway.
The Real Maverick
Jack
Agree.
But from Ford's perspective the 12v battery only needs to last 3/36,000.
