Grabber Rick
Rick
Sarver Pa.
07 Focus wagon 06 Silverado 4x4
It was a lot easier than I expected I started at the dash cam I used the OEM mirror mount verses the straps - routed wires inside black shroud above mirror to access the headliner (it pops off easy) tucked the wires as I went towards driver‘s side A Pillar popped the trim covering it carefully then routed rear camera wire and power wire behind the air bag - worked my way down the trim on the side of the dash drop into the dash cavity there with the power cord being I used the OBD II Port for power verse going to the fuse box On the passenger side
i continued lifting the trim along the bottom of the door did a little crossover at the center door post then continued under the trim across the rear door then up the door trim until I got to the top of the back seat
i worked the trim openings up to the head liner across the back glass - removed the 3rd brake light unplugged the camera and snaked the plug and cord from the outside and reconnected it and tucked it into the headliner
good luck if you decide to go this route it was pretty easy honestly
I have a Pelsee mirror dash cam. I thought about fishing the wire under the headliner straight back to the rear. Seems like there is agap between the headliner and the roof. I pushed on the headliner and it seems to flex upward. Hopefully I can push a fish wire from the front roof panel to the rear dome light. What do you think?
Dave O
Dave O
New Smyrna Beach Florida
I think it’s possible I’d definitely start at the dome light and go forward towards the windshield (assuming you don’t have a moonroof) pulling down the headliner at the windshield to fish the wire towards the rear could be a challenge I only needed to pull the headliner down about a 1/4” - 1/2” to tuck the wires in the headliner note the headliner is a lot more ridge than I would of thought thankfully no damage occurred and the headliner looks as good as it did before I started the project
Grabber Rick
Rick
Sarver Pa.
Thanks for your opinion. I plan on removing the overhead console trim at the front. I don't have a moonroof. I got a adapter that plugs into the harness under the front overhead console. I will just have to be careful not to poke a hole or make a mark on the underside of the headliner that may show through. I will make sure I tape the end of the fishwire so if I have to pull it back I don't snag anything. Hopefully I can get it through in 1 try.
Dave O
Dave O
Sounds like a good plan Rick I look forward to seeing some pictures of your install - good luck 👍
tpollauf
Toledo/Port Clinton, Ohio
1992 F-150, 2009 Pontiac Vibe GT, 2026 Maverick Lariat Hybrid
Didn't know where to add my comments to how valuable these rear cameras are vs using the interior mirror. Attached is a pic (poorly taken by me) showing the 5-ton air conditioner that I was transporting using the Maverick. It was just tall enough to completely obstruct my view out the rear window. Now had I had the rear camera mounted above the 3rd brake light, I would easily been able to see everything behind me. This further reassures me that when I get my own Maverick this summer (currently driving a company car maverick) my first mod will be this WolfboxG900 Pro setup. Thanks to all who already own one and encouraging others like be to get one!
Ford Maverick WolfBox G900 TriPro Dash Cam Installation Completed IMG_6037
nbmav
Kevin
North Bend, WA
2026 Lariat
Did you ever end up fishing the rear camera wire under the headliner? I was thinking of doing this instead of what I did last time which was a real pain.
SRQAMT
Nik
Knoxville
'26 Lariat AWD
Dave,
Nice write up.
I think when you move the camera to your rack you will be impressed with how much view you gain in your Wolfbox.
I have a Wolfbox G850 and originally had it mounted in my back window right passenger side which gives the maximum coverage for the lane on the right.
I ended up purchasing a second waterproof camera and extension and ran a line to the back right corner of my tonneau cover which gave me an even better view.
The problem remains with both views that it is hard to determine the distance of the vehicle behind you.
I’ve recently give a new location below the tailgate a shot.
I have temporarily mounted it at the correct height and depth so that it is protected from damage, constant rain and has clearance for when the tailgate is dropped. I’m hoping this position also reduce drops blocking the camera.
I have to reach out to some friends who 3D print as I have no idea how how to cast the contour the space to make a solid mount.
If anyone who 3D prints could tell me how to achieve this please DM as I would appreciate any help.
Sorry to resurrect this, but I'm planning a wolfbox install and this is where I want my camera to sit, because I have a wildtop on my truck most of the year.
How long have you had the camera in that position? Pros and cons? Can I do it with the camera setup the wolfbox comes with?
Also, could you give some details on the process required to get the wiring from out there to the cabin?
I have a 3d printer, but I haven't learned how to model things yet...I'm sure I could find something to print and stick the camera to though
ryan2366
Ryan
2025 Maverick Lariat - Hybrid AWD
Hey,
I’ve had the camera there for several months. Picture is great. I haven’t got around to making a proper mount yet. The only issue with the camera in this location is road spray when it’s raining. It naturally settles on the camera in more of a mist than droplets.
I have access to a 3D scanner and plan to make something more stable which fits the contour of the bottom of the tailgate.
Basically just a block which allows the camera to sit recessed from the outer edge of the tailgate and high enough that the camera clears when the tailgate is put down.
I plan to add a spray nozzle to the mount I make which will be connected to a horn air compressor to clear any build up with a blast of air. Using air instead of fluid like the ones you add to yours windshield fluid which cost over $100.
$17 CDN - Horn Air compressor
https://a.co/d/00Mw2Qtj
$22 CDN - Sosolong 4pcs Front Windshield... https://www.amazon.ca/dp/B0CDTRDKQC?ref=ppx_pop_mob_ap_share
Running the wire to the camera is easy. Just run it from the tailgate through the opening for the tailgate wiring to the rear wheel well.
From there you can find a factory grommet near the air vent by the right rear passenger to pass the wire through to the cabin.
SRQAMT
Nik
Knoxville
'26 Lariat AWD
Hey,
Very interesting, and thanks for the response. Have you tried a highly hydrophobic spray or ceramic coating + rainx combo on the lens before delving into pressurized options?
ryan2366
Ryan
Yes,
Didn’t have much success
