Window Regulator Issues
Nameless
Baltimore, MD
2023 Ford Maverick AWD XLT
Anyone have issues with window regulators?
My windows have always been a bit flakey. The passenger windows (all 3) would intermittently stop when rolling up and down, but have always been able to completely close/open by letting go and pressing the button again until yesterday.
I rolled the passagner rear window down, and it wouldn’t go back up. There was a click in the door when I would try, but no glass moving. I took it to the dealership today and they said it needs a new regulator. They put me in a rental and said it would be finished tomorrow.
Anyone else have issues? There is a thread this forum (https://www.mavericktruckclub.com/f...stuck-down-quick-fix.35074/page-2#post-852338) about the drivers door switch being the culprit, but I’m going to let the dealership do their thing and trust their diagnostics.
AK ADQ
Leon
Alaska
2004 Jeep Liberty 2010 Dodge Journey
My passenger front window when you put it into auto up it will go to the top and come back down 3/4 of the way down. In order for me to close the window I have to raise it close to the top, stop with the button and then raise it to completely close the window. Sometimes a inch or so at a time.
Montana
Do you by chance have in channel deflectors?
JayBoegs
Jay
Los Angeles
2023 Hybrid XLT Maverick
I have the common rear passenger window stuck down issue. FoMoCo has asked for my info. Local dealer gave me a July 30th appointment. 2 months from now. Crazy.
paneubert
Seattle
I was going to mention the "drivers door switch being the culprit" thing, but I see you already found that. Let us know if this is another case of that, since it adds to the pile/trend of drivers controls seemingly being somewhat faulty on the Mav. I don't know if I have seen anyone post that it WASN'T the drivers door controller that went bad.
Nameless
Baltimore, MD
This was my concern also. I haven’t mentioned any research I’ve done to the dealership. I’ll let them try to figure it out, if it’s not finished tomorrow I’ll call and talk to the service advisor.
fossil
ernie
ohio
Resetting One-Touch Close
Carry out all steps within 30 seconds of starting the sequence.
Close the window.
Press and hold the window control switch until the window is fully open. Keep the window control switch pressed for two seconds.
Lift and hold the window control switch until the window is fully closed. Keep the window control switch held for two seconds.
Press and hold the window control switch until the window is fully open. Keep the window control switch pressed for a two seconds.
Lift and hold the window control switch until the window is fully closed. Keep the window control switch held for a two seconds.
Note: Repeat the procedure if the window does not close when you use one-touch.
