Has anyone else had issues with passenger window not rolling up?
callen4794
C
LA
2016 Ford Expedition King Ranch
All other windows work fine. It will roll down, but it won’t roll back up. Pretty inconvenient that it happened right before a long road trip. Anyone else know anything about this issue?
happened the first time at 2k miles and here again at 4500 miles.The first time, it started working again after about a week.
There was a number of trucks having the passenger rear window switch fail and sometimes taking the window motor out with it.
You have a warranty. Take it to the dealer.
Poultrygeist
Paul
South Carolina
Accord, Soul
Silicone spray on the rubber window seals can work if the glass is sticking. If not the actuator probably needs replacing.
UberGadgetFreak
Mt. Holly, NC
03 Marauder, 21 Bronco, 22 Maverick
Could try resetting the window switch/index:
From the Owner's Manual:
Carry out all steps within 30 seconds of starting the sequence.
  1. Lift and hold the window control switch until you fully close the door window. Continue to hold the window control switch for a few seconds after you close the window.
  1. Release the window control switch.
  1. Press and hold the window control switch until you fully open the door window.
  1. Lift and hold the window control switch until you fully close the window.
  1. Test for correct window operation by carrying out the one-touch down and one-touch up features.
Ford Motor Company
Official Ford Account
Dearborn, mi
Hello! Send us a private message with your VIN and the name and location of your local Ford dealer. I’d be happy to see what I can do to assist with this window concern. Thanks!
Stock411
HI
2022 Ford Maverick XLT Hybrid
Yep, happened to me like the other guy said, a small number of Mavericks got shipped with a faulty window switch. It could be intermittent or just completely fail, so get it fixed ASAP.
Here’s what I did to get mine up before the dealer could replace the switch. I keyed the ignition on and spammed the window up command for that side and eventually it went up. I just never rolled it down again till they fixed it. It may work for you till you can visit them.
callen4794
C
LA
I ended up spamming the switch while I was driving yesterday and got it rolled back up eventually 😂
Stock411
HI
Get it fixed ASAP, it will only worsen. I put off mine for a bit since the dealership was far and before I could get It to roll up now, then soon as I turned on the truck it’ll roll down by itself. So at that point I brought it to the dealer and told them to put it back up since the part wasn’t available. So they did and disconnected power to the motor till the replacement switch came in.
sanhozay
gary
Central California
22 Maverick XLT LUX 4K
I have the same issue on my rear passenger side window except my motor sounds like its broken. When i hit the window switch it sounds like a plastic crunching up, but the window does not move. Is this an issue that Ford is aware of?
Timaysz
Southern Wi
Ford explorer sport trac
Ya mine just did it to me yesterday rolled all the windows down to let the hot air out when I started driving then rolled them all up and the passenger rear won't go back up u can hear the door click when trying to roll it up.. But just stays down... Only have 4300 miles on the truck was built in the beginning of Jan 23
Call sign "Slick"
Wain
Houston, tx
2023 Ford Maverick
It's now happened to me twice!
Going back to the
dealer next week!
