Will Remote starting hybrid maverick turn on the engine ?
kkgg
Minneapolis
I hate getting in to cold car in winters. I usually turn on my EV and heat the cabin 10 min before I start.
I was wondering if remote starting the maverick(hybrid) will just warm the cabin in battery mode(not starting the engine) !!
Thank all
Gullzway
OK
1968 Ford Mustang Fastback
Seems random on mine.
I've remote started it in 30 below weather and gone out 10 minutes later and it's not running, this not warm.
Sometimes it is.
kkgg
Minneapolis
I don't have problem with the truck starting the engine, but it's annoying to open the garage door every time I remote start
Gullzway
OK
I park mine in my garage, I never remote start it at home.
Only at work, or away from home if parked outside.
Will Remote starting my hybrid maverick turn on the engine ?
A very Valid question, but It so sounds like a Monty Python skit :D
The Real Maverick
Jack
Thank all
It will pre-heat but the gasoline engine needs to run.
But you need to remember to turn on the heater settings before shutting down the day before. (Maybe AUTO will do the same, I rarely use AUTO.) Also, if equipped, you can set it to have seat heaters and steering wheel heaters automatically come on too.
To be clear... only burning gasoline will heat your truck cabin. There is no way to heat the air with electricity alone. But you can heat the seats and steering wheel (if equipped) and those devices take trivial power. About the same power as headlamps. So use them!
I just cannot wrap my brain around the thought of
‘Pre-heating’ with the hybrid engine off.
So ten minutes later you get into your Mav with a pre heated but cold engine and drive off into traffic,
With a cold engine ?
My heated seats and steering wheel would not be enough by its self.
My ‘Auto’ air has three intensity levels. It is set to the middle level.
Ten to fifteen minutes after a remote start my cab and engine are all happy and warm.
Does the pre heated give you hybrid drivers a warm/warmer cab ?
Any warm air flowing out of the vents ? Defrosted windshield ?
mikellmikell
Mikell
Southwest Michigan
2 Colorado's
At 0 outside last week within 10 minutes it had melted the windshield and I couldn't see my breath inside. It started after less than a minute and I always set it on MAX when I get out.
topgun/goose
earth
metro
My new 25 xlt lux hybrid turns on the engine and even turns the hvac system on if I had turned it off on the last drive including the steering wheel and seat heaters. Its like it remembers where I like to have the temperature at and since it has auto it gets everything going just the way I like it, what a smart truck. It is so nice to get off of work and get into a nice comfortable truck to go home in, I love this little truck more evertime I drive it.
Cfriedman1
Curtis
West Virginia
Thank all
My 22 mav starts 8 out of 10 and does heat up the cab..
SuperDave71
Carthage IN
Ford F-350 CCSB 6.7
I seem to recall that my early 22 XL had an electric heating coil that would engage if Max heat were selected and the ambient temp was below a certain temperature. I witnessed the current draw on my scangauge II. I know my 23 XLT does not respond in the same manner.
Master Blaster
Master
Toronto
23 Maverick Lariat Hybrid
No. Firing up the gas engine has nothing to do with a running status. Unless you already have the battery in a low state of charge, it will start into battery-only operation. If you put the climate management into max heat it will use the battery to heat a small electric heating coil in the airflow. If you put the defrost mode on then the electric A/C is engaged. Both of these will fairly rapidly deplete the battery and the engine will soon fire up to recharge it. When the engine fires up the resulting hot water will add to the cabin heating.
The bottom line: If you live in the snowbelt then don't get the base model XL. You need the steering wheel and seat heaters instead of warming the entire cab.
SuperDave71
Carthage IN
Ford F-350 CCSB 6.7
Here is the post I was remembering, I cannot seem to copy a link
Ford Maverick Will Remote starting hybrid maverick turn on the engine ? IMG_6749
PTLove
NJ
Hyundai Santa Cruz
If your climate it’s set to Auto, the Maverick will do whatever it has to to hit that temperature. Out will turn on the engine if it must.
