What tuners can increase or disable the speed limiter?
THEMAV2022
ADAM
north carolina
2022 FORD MAVERICK MAVERICK AWD XLT FX4
Will any available tuners on the market increase or disable the speed limiter? I don't think forscan can disable it.
Maverickman74
Shane
Maui HI
Old school hack is get the tallest tire you can fit. It wont get you much but its something.
rlhdweman
Random Lake Wisconsin
I wonder if Forscan can just change it? such as closer to the limit of the tires.
THEMAV2022
ADAM
north carolina
The speed limiter is in the PCM, and Forscan does not support PCM modifications. You need a hand held tuner.
Old Man
Nebraska
2023 Lariat
Are you talking about a Dark Horse Mustang? Why would you ever do over 108 mph in a Maverick?
Snox801
Levi
Spring Lake Michigan
Because Merica!
Before you state things like that maybe think about what he’s doing. I’ve been over 108 in mine several time now.
I enjoy the thrill of speed. Same reason I pay for open track days so I can go as fast as I’m comfortable, turn as aggressively as I want and get a bit crazy.
He may also be a first responder which sometimes out by where I live you need to go a bit faster to get anywhere at a decent time.
Snox801
Levi
Anyway Livernois raises the limit on the tunes they offer. 108mph doesn’t even get you half way down the straight at gratten or gingerman raceway.
Automan21
Mel
‘23 XLT Eco AWD 4K Tow
Cobb sport tune won’t let me pass 108. On a closed circuit course of course.
Will have to try the OEM+ one.
Master Blaster
Master
Toronto
23 Maverick Lariat Hybrid
You're driving an aerodynamic brick. The speed limiter is there to stop you from lifting off the pavement and losing control. Why on earth would you remove that, knowing its going to kill you?
Automan21
Mel
I agree with the brick analogy. I doubt this little guy will go fast enough to get airborne. But for some who like to auto cross and track their Mav it would be something worth looking into.
rlhdweman
Somewhere recently on this site was a list of items that forscan can alter, one did indicate that the speed limiter can be raised, but not removed. Would be interesting for someone to get a mild tune with the limiter removed, & under a controlled situation to see how fast one will actually go. I am thinking that around 130 you will be reaching the limits of aerodynamics-engine power/effectiveness of the intercooler. With a healthy tune upgraded intercooler a better intake & tires what would be the result. I am sure we will find out in the near future.
