What Makes a Good Performance Aluminum Radiator? - Mishimoto
Mishimoto
Gold Sponsor
Josh
Garnet Valley, PA
2022+ Ford Maverick
What makes a performance aluminum radiator actually perform? At Mishimoto, radiators are at the core of what we do — and the question we hear most at the track is: "My temps are creeping up… do I just need to go bigger?" A performance aluminum radiator can absolutely transform your cooling game — more heat rejection, better durability through heat cycles, and the consistency you need when you're pushing hard lap after lap. But here's the thing: raw size doesn't win races. True cooling performance comes down to the entire system — airflow, fan pull, and the engineering inside the core itself: tube construction, fin density, row
configuration, and how it all works together under pressure. A track build has completely different demands than a tow rig or a street car, and choosing the right radiator comes down to matching the design to the vehicle's intended use. The right radiator isn't the biggest one — it's the one engineered for how you drive.
Dive into the full breakdown here: https://www.mishimoto.com/engineeri...-core-thickness-tube-design-airflow-explained
Also, don't miss your chance to win a FREE radiator of your choosing. Enter to win below!
https://www.mishimoto.com/aluminum-radiator-giveaway-april-2026
Ford Maverick What Makes a Good Performance Aluminum Radiator? - Mishimoto Radiator_Blog-7
Tbone289
Ah! I see what you did there. ;)
What I don't see is a radiator available for the Maverick on your website. All I see are lugnuts.
710
MICHIGAN
2022 FX4
Said rads in development will be an upgrade from stock fx4 package???
I would line up for that!
Also, related but possibly belonging on the FMIC thread, reading the post here, I was going to chime in the observable differences between yours and competitors FMIC. Noticeable differences between FMICs are the tanks and the number of plates (if I’m using the correct terminology, the plates between the rows of fins) To call them by name, Buschurs uses seven rows of plates, eight rows of fins, CVF uses eight rows of plates, nine rows of fins, and MISHIMOTO uses twelve rows of plates, thirteen rows of fins.
Seeing as how you are the company with the largest budget therefore the biggest ability to perform R&D, I’m very curious how you arrived at the configuration for the final product! Surely you must have tested multiple prototypes before deciding on the final production. Can you offer any insight into how and why you chose the final configuration without giving away any proprietary design secrets?
Thank you!
Mishimoto
Mishimoto
Gold Sponsor
Josh
Garnet Valley, PA
2022+ Ford Maverick
Thank you!
Not sure about specific numbers over the FX4, we'd have to check w/ the engineers.
As far as the intercooler question goes, you're spot on with the assumption that multiple configurations were tested. Based on the space available, we provided Ford with a few different configurations that had different dimensions, row counts, fin height, etc. Based on their results, the production version was the sweet spot that combined best overall cooling performance with an optimal pressure drop. Too much pressure drop and your turbo will be strained trying to maintain the same boost levels. Hope that helps!
