what drugs is my Maverick taking?
RatherBeDrivingaManual
GBP
Maine
NA Miata, Subaru Legacy, XLT Mav
I woke up this morning and I had to ask myself... am I seeing things as they are not... or was my Maverick taking LSD last night? (not disclosing how I would know what that looks like).
Ford Maverick what drugs is my Maverick taking? 20230912_085019
Ford Maverick what drugs is my Maverick taking? 20230912_085647
Ford Maverick what drugs is my Maverick taking? 20230912_085727
Being serious... everything had this distorted, ghosty, blurry, topographic map effect to it. Even the Ford logo on startup & shutdown.
GBP
Maine
When in doubt, reboot.
I actually tried that. I shut the truck off. Opened the door, took the key out. Gave it many seconds. Shut the door. Started the truck a second time. Same issue with the screen.
Issue went away later, aka was not present next time I drove.
Gullzway
OK
1968 Ford Mustang Fastback
jsus
2022 Ford Escape Hybrid AWD
Next time, you can give this a try (obviously the button locations are different than the reference graphic):
Press and hold both the Power button (center of the Volume knob) and the Seek Right button for 10 seconds.
Ford Maverick what drugs is my Maverick taking? 7301c8d6-7dcd-4b2e-b498-133136e070bd
https://www.ford.com/support/how-tos/sync/troubleshooting/how-do-i-reset-the-sync-system/
Montana
That's not very reassuring. Sounds like maybe a loose connection or a miscommunication. I'd be removing it and checking connections. It is a very easy process to remove if you run into it again so you can troubleshoot before throwing the warranty into the mix (hopefully not needed) to at least double check for any loose connections or bad wiring. I dunno... after the one report of someone's vehicle basically melting from behind the dash... a bit worrying.
Ford Motor Company
Official Ford Account
Dearborn, mi
Hi there, I'd be happy to look into your Maverick concerns on my end. Will you send us a message with your VIN and dealership info? I can look into things on my end.
ShadowBlack XL440
Robert
Northern Ohio
Cheap electronics can prove to be expensive.
