Weight in the back / bed -- 470 lbs load ok?
LanceMav
Lance
Sutherlin, OR
2025 Maverick XLT
Need to make 1 hour drive to get some pavers. Approx total weight is 470 lbs. Can the Maverick handle this? It's 90% freeway drive.
JP&R
2004 bmw 330i ZHP 6 Spd sedan,
Um, really that’s a question, …. Ok
Cancunbadlands
Cancun
Cancun
You'll be ok
Tbone289
There's a sticker on your driver's side doorframe that shows the exact load capacity of your Maverick, which varies depending on equipped options. You won't find this information in your owner's manual, but you should read that too.
Ford Maverick Weight in the back / bed -- 470 lbs load ok? 1754841181874-hy
JMJB
Fresno California
'22 VB XLT Hybrid with Sunroof
If not reading the manual , how about that bright yellow label you see every time you open the drivers door ...😁
PlantMan
Berwyn Heights, Maryland
2017 F-250 4WD crew 8' bed; 2022 Maverick XL AWD
Good grief!
Jah.
Jah.
Central Florida
Here is my loads . bag of gravel weight about 800 lbs . no problem and didn't notice any performance difference .
Ford Maverick Weight in the back / bed -- 470 lbs load ok? 20240407_120450
Ford Maverick Weight in the back / bed -- 470 lbs load ok? 20240308_114734
Ford Maverick Weight in the back / bed -- 470 lbs load ok? 20231108_093817
LanceMav
Lance
Sutherlin, OR
2025 Maverick XLT
Thank you for all your responses. Yes, I should have looked at the door sticker/owners manual, just was not thinking. New to this smaller truck and was not sure of the capacity. Got my pavers today and thanks again to all.
Cancunbadlands
Cancun
Cancun
What's your VIN number
Mavster Mechanic
Hybrid
All good.
I put over 1,000 lbs in my bed about once a month.
If you travel at night your headlamps will blind others. Even with 300-400 pounds your headlamps will be mis-aimed.
So try to only do heavy hauling in daylight.
Darryl
Darryl
Tallahassee Florida
2025 Maverick XLT HYBRID
Understandable. We all sometimes overlook the obvious. You're only human. You've probably discovered that this is a very capable truck
