sanhozay
gary
Central California
22 Maverick XLT LUX 4K
Found my tall twin today. Not sure if it has a lift on it, but figured some side by side comparison shots might come helpful for people trying to decide on the lowering kit.
Ford Maverick Visual height comparison: Eibach lowering springs vs. stock FX4 suspension 41A12BA1-9A44-4991-A61D-23C65BCA32AB
Ford Maverick Visual height comparison: Eibach lowering springs vs. stock FX4 suspension EC3A8D10-4EB7-4A5C-8547-9353065BF227
Ford Maverick Visual height comparison: Eibach lowering springs vs. stock FX4 suspension 2DE9262B-8213-4449-9B61-0F2BA23E0D80
Ford Maverick Visual height comparison: Eibach lowering springs vs. stock FX4 suspension 5086ECC4-7D4F-426F-AC1A-8FAA5A6A7EDE
Ford Maverick Visual height comparison: Eibach lowering springs vs. stock FX4 suspension A2987A9A-8F60-4D36-9BD9-ACA4A7E039D1
Ford Maverick Visual height comparison: Eibach lowering springs vs. stock FX4 suspension 37D8400D-0907-4011-9FA9-6603FA3EB0CE
Ford Maverick Visual height comparison: Eibach lowering springs vs. stock FX4 suspension F48BE740-35C7-4540-B0F6-DCD0369ACD8B
bgn
WA
An FX4 doesn't ride any higher than say a standard Ecoboost AWD w/ 4kTow, no?
Correct. The different suspension setups are the following:
Hybrid
AWD (with or without FX4)
Tremor
TedTX
Ted
San Antonio TX
Unrelated side question. Does the cover ( got same type ) fit over the white tank in back? If so what size/model did you get to fit? Need something like that for Ag use.
FischAutoTechGarten
Peter
Hybrid
Tremor
I know FX4 intoduces a 'mono-tube performance shock' (different part numbers have been confirmed by others in other posts).. but yeah, the ride height is no different.
I would like to see a Hybrid XLT parked next to an EB XLT (say with AWD an 4K or FX4) to see the ride height difference.. I can't help but imagine that with the focus on fuel economy of the hybrid that Ford was tempted to have it sit just a tiny bit lower to improve aerodynamics.. I wonder if even the EB FWD sits lower than the an EB AWD...
Barksdale123
SoFla
2023 Ford Maverick
Nice job on the comparison. And the color....... Out of this world!
Cool, and what size tire are you running? I see it's not stock, but people have used a lot of varying sizes aftermarket.
Can you list the differences in suspension setups & heights between these three?
hybrid should be the same as fwd ecoboost. any FWD Maverick has a torsion beam rear suspension instead of mcpherson strut like the AWD models use. every model except the tremor is rated for 1500 pounds payload.
tremor is, according to Ford, 1" lift and 1200 pound payload.
presumably every manufacturer offering lift or lowering springs has measured the stock spring free length and rate, but I've never seen it published by anyone.
Tire is 235/55/18 continental extremecontact dsw06+ on 18x8.5 Konig heliograms
that's a shorter than stock tire, interesting. I am planning to wear out my stock 235/60-18 Michelins and thought to use a 255/55-18 next, which is a 29" tall tire. Numerous people are using tires that height with eibach lowering springs.
sanhozay
sanhozay
gary
Central California
You might have clearance issues with the driver side rear with 255’s, there is less clearance in that wheel arch sidewall. My 235’s barely cleared. Maybe with a lower offset wheel it may clear, my konigs are 42+ offset
Ford Maverick Visual height comparison: Eibach lowering springs vs. stock FX4 suspension 3D573DCB-C1C7-411E-AD52-1EE649643DB6
yep it's going to come down to tires. I will be using the stock 18" wheels which are 18x7 +37.5 I believe. but if I need a 5 or 10mm spacer, I'll use one. I'm probably a year out, anyway. Michelins going strong 🤣
