Very Low Speed Driving Hybrid Weirdness
inline_five
2023 Hybrid XLT
For what it's worth there was a TSB to address this.
Mine came from factory with that installed, it's a late August '23 build. No TSB needed.
This isn't a shudder, it reminds me of an old auto transmission that drops out of gear when slowing to a stop as the pressure falls off.
Well, what the original poster for this thread is describing sounds much more like the typical brake grab/lack of response when inching. Which is different from what your thread details.
kboom180
Kurt
VW
After some confusion with the dealer (they had no idea what I was talking about) and them asking to test drive in which they somehow couldn't replicate the problem, finally got the update. It was a reprogramming. It helped slightly. But, it still is weird at low speeds. The clunking does sound worse now with 30k miles. Definitely a design flaw that should have never made it to production. With that being said, after about 10 miles an hour, the hybrid/gas system is flawless.
CurtisB
2023 Maverick XLT Hybrid
Haven't had this issue. Mine was built 08/03/2023.
kboom180
Kurt
VW
So, when you come to a smooth and controlled slow speed stop, there is absolutely no noise or pedal modulation? It brakes completely like a non-hybrid vehicle? Perhaps the the issue had been fixed at some point. Mine was pretty early in production.
CurtisB
When driving a hybrid, there are a lot of different things to get used to. My 2015 Prius did the same thing. So, it doesn't feel wierd. I have 9 years of hybrid driving to compare the Maverick to. The one thing that the Maverick does better than my 2015 Prius is that it stays in the "electric mode" longer and more often than the Prius.
kboom180
Kurt
VW
It is something I have gotten used to. But initially it was just straight dangerous. The truck would not stop unless you smashed the brakes. It was that issue that should never have passed the final ok. Even in a 20k truck. Ford knew, Ford didnt care. Otherwise, im as happy as you can be for a very cheap vehicle.
Sharksforarms
Missouri
I get a clunk when I am slowly coasting and the truck transitions from Regen to physical brakes. Never seemed unusual to me.
CurtisB
I really think you should take it to your dealership. I am not having that type of problem at all, nor did I with my 2015 Prius.
kboom180
Kurt
VW
Its a very well documented issue. NTSB took action. Ford will just say its normal. Which I believe. If you read up the thread, the main problem was fixed via software. Just dont think its designed well. I've driven hybrids from other car companies and have never had clunks and noises. It is what it is. A 20k truck haha.
inline_five
2023 Hybrid XLT
So mine is great down at very low speed. 8/23/23 build. It stops extremely smoothly. However, my event happened around 20mph, and felt like one of the electric motors engaged when it shouldn’t have and it rocked the motor on its mounts.
agmonaco
Tony
Pittsburgh
2024 Ford Maverick Hybrid
Mine will have a slight clunk when coming to a stop sometimes. It seems to only happen in electric mode. Mine is a 2024 Hybrid Lariat built in September.
Master Blaster
Master
Toronto
23 Maverick Lariat Hybrid
Factory Ford brakepads are hygroscopic, so if you have not driven it in a day or are driving in wetter conditions then they grab pretty badly. Its really noticeable below about 4mph, when the regen braking is disabled and it abruptly transitions into friction braking. There are 2 problems here: wrong factory pads and a software error at the transition point. The software error was corrected in early 2023 and then reintroduced in the latest recall fix. Ford, are you listening?
TheSEARCH
Dan
ford
2023 Hybrid .Brakes can be grabby at first more when wet and raining. Get up to 35 mph. Put into neutral apply brakes some what hard. Then back to normal driving rest of day. ONLY done at very first drive of day. No need for any update from ford.
Regen has no difference in electric or ICE mode when braking.
Only difference is if the ICE running and since no power needed for braking the generator motor may be recharging the HVB also, along with the traction motor for regen.
Or the battery is charged up to max and the generator is changing the gearing for the engine to take some load from the traction motor.
But the chances of that always occurring at the final stop and not different times during the coast down - unlikely.
