Use L instead of eco?
mamboman777
Josh
NRH, TX
I've discovered that when I use L my hybrid uses the most possible regenerative braking. Is there a downside to using l when I want to slow to a light, then out of l when I take off? I'm getting good mileage out of normal mode, so that's not what I'm after. I think "L" is essentially maximum Regen.
Thoughts?
MLA62563
Charlotte, NC
Honda Accord, Ford Maverick
Thoughts?
Good question! I have been wondering the same thing. Looking forward to some helpful input.
No real downside. I still use it concurrently with Eco as I drive with cruise control frequently and Eco keeps it from wanting to accelerate as hard to maintain speed or when adjusting with the switches.
icegradner
British Columbia, Canada
2022 XLT Maverick Hybrid
L is engine braking, it's just throwing away energy. From what I can see using L gets less regn coming to a stop. If I use it when I could have lightly braked, I tend to get 80% or less return, compared to using the peddle getting 100% 😐 I only use it on steep hills or if traffic slows faster than I anticipated.
mamboman777
mamboman777
Josh
NRH, TX
I have seen it turn on the engine before, but most of the time for me is doesn't. Using torque pro and an obd2 adapter, I can see it regens faster with L than coasting alone.
icegradner
Guess the truck decides based on your speed, every time I've used it, engine comes on. I find just coasting the truck slows down too much on the gentle hills I'm on most of the time, so I have to use the accelerator peddle to maintain speed.
TedTX
Ted
San Antonio TX
I like it for winding roads. That have many sharp turns. There is a shortcut to my ranch from my house the drops almost 2 miles from trip total. L helps keep it one foot action to speed up and slow down like a golf cart.
TedTX
Ted
San Antonio TX
It’s a fun road for the Maverick being so low to the ground and only slight body roll. The shortcut was a workout in my full sized Texas Edition Silverado so rarely used it. The road reminded of the PC game ‘need for speed’ in that it has the rare pine trees this far west of the east Texas Pineywoods. and South of Bastrop.
I use L frequently. It is great for stop and go traffic where with very little practice you can one pedal drive and only use brake to come to complete stop. L will Regen to lower speed than each gear not in L. Helps in stop and go by much reducing hydraulic brake grab. Downside is Regen will rapidly fill HVB to 70% where Regen is greatly reduced and ice will start engine braking. Since battery will not accept the high Regen braking current safely. When in L if you want to get 100% braking you cannot touch pedal while brake gage is over about 60% or you will also activate hydraulic brake and drop return to 70-90% in a heart beat. Even then you will need a light touch above 15-20mph. Also do not overlook slippery mode particularly at highway speeds. It has the weakest Regen braking and will coast much further. You can save the conversion loss of momentum to stored current in battery. Search for member GPSMAN and slippery. He has run many tests in all gears and compares. I think he is 700+ miles per tank sometimes.
Thoughts?
Additional thought. Normal mode with L is stronger Regen than econ mode with L and slippery mode with L is less regen than econ with L. I haven't ever tried sport mode at all, yet.
mamboman777
mamboman777
Josh
NRH, TX
Good thought.. Texas here....I don't get into slippery that much.
Slippery can be used on wet and slippery surfaces but TRY IT ON REGULAR DRY. It feels like driving a regular automatic (coasts for ever with minimal Regen). It will allow driver to brake more aggressively Regen braking without engaging hydraulics. Without flooring go pedal but with reasonable acceleration I can regularly get 40+mpg without trying, just regular driving. I am NW of Austin, TX, Burnet - Marble Falls area. Again read gpsman posts concerning slippery. Have fun!
TedTX
Ted
San Antonio TX
Good points. Like slippery mode for general driving even in city like conditions where I can coast. Truck coasts really really well.
Jville
Jacksonville
2022 Maverick Ecoboost awd
Thoughts?
I don't see much difference with eco/L over normal/D. Usually get 46-51mpg either way. 36-40 highway.
Obviously engaging L helps save brake wear, especially downhill.
