Turn signal hyperflash disable (FOUND)
CA$H
CASH
SAN DIEGO
22 FORD MAVERICK
MichaelG
Michael
SE Michigan
2002 Ranger
Because i can and i want to!?
Why do you want to blind other drivers with your flashers? I understand upgrading the backup bulbs, but the indicator lights don't need to be bright. They are only for other drivers to see your intent.
MLowe05
GA
Spend the money on Lasfit. They make quality stuff and you don't need to mess with wiring.
MostlySafeBear
San Francisco, CA
(Eventually) a Ford Truck
I agree. As much as I love the DIY spirit, there are times when it's a wiser move to spend the money on a finished product that does what you need.
If it's just a matter of a Forscan setting then it doesn't cost any more and solves some of the limitations of even the Lasfits (like they still hyperflash once they get hot after prolonged use).
MostlySafeBear
San Francisco, CA
The FORScan method involved losing bulb outage detection, which is after all the reason that signals were intended to hyper-flash for.
Since the turn signal bulb on a Maverick is also your brake bulb, losing them could subject you to a law enforcement encounter, something that I prefer to avoid at all costs.
That presumes the load resistor integrated in the Lasfits doesn't prevent outage detection from working if the LEDs should fail.
MostlySafeBear
San Francisco, CA
That's moving the goalpost. The FORScan method involves outright disabling the detection of turn/brake bulbs that are out, so we know that it will not work.
Crazyal
Al
Alberta
2022 FE, Lariat, Lux, 4K, 2022 Ford Edge ST
I agree, worth every penny
90.eunos.cosmo
90.eunos.cosmo
Alexandre
2014 fiesta ST, 22 ford maverick
Almost everyone i speak to that have installed lasfit still or will have hyperblink and they also prevent hyperblink detection because of the integrated resistor... so point here being, the forscan methode is cheaper and works 100% of the time IF the option is available for the maverick
Jared
Jared
Ford Maverick XLT
Seems pointless if you can simply add a resistor. Resistors are cheap.
