Turn signal hyperflash disable (FOUND)
Chris_G
NOVA
C-6 Corvette
90.eunos.cosmo
90.eunos.cosmo
Alexandre
2014 fiesta ST, 22 ford maverick
That's moving the goalpost. The FORScan method involves outright disabling the detection of turn/brake bulbs that are out, so we know that it will not work.
No, you can choos3 front and rear independantly... the lasfit bulb will prevent you to get a hyperblink when tthe bulb fails as well
90.eunos.cosmo
90.eunos.cosmo
Alexandre
Out of curiosity did you try the Front LED Turn Outage setting as well?
You sir have a point! I will test this out when i have a chance
90.eunos.cosmo
90.eunos.cosmo
Alexandre
Seems pointless if you can simply add a resistor. Resistors are cheap.
The whole point is to not modify the harness.... to me it seems pointless if you can do it for free with forscan and not pay a dime or damage the oem harness
90.eunos.cosmo
90.eunos.cosmo
Alexandre
Wouldn't two lines down "front LED bulb outage" enabled tell the system to treat bulbs as LED's instead of incandescents?????
I will try this once i get my led bulbs!
olderbudwiser
Put the original bulbs back in. I don't get the need to have super bright lights. Aren't the stock bright enough?
You are no fun. Don't you want to add 6 lights to the roof of your Maverick and 4 in the grill each capable of 50,000 + lumens. Should be able to fry an egg at 20 feet on hood of a car.
Too bright tough. I want it. Just wear sunglasses at night.
NJBob
New Jersey
Sorry for my ignorance but how does canbus works
90.eunos.cosmo
90.eunos.cosmo
Alexandre
Actually i'd like a led bar eventually because i do alot of night offroading to go to my trapping camp!
90.eunos.cosmo
90.eunos.cosmo
Alexandre
No such thing as ignorance my friend
Canbus is intermodular communications... so lets say, a headlamp goes out... the bcm will recognise it and send a signal to the dash control unit to let you know you have an issue
Or lets say you have a problem with your speed sensor
The tcm will send the information to the ecu so it might derate your engine then it will send that information to the bcm and the bcm will decode that information, send it out to the dash control module and let you know tlwhats going on
I used to build police cars and the system is so fragile that if you connected the wrong seat belt buckle at the wrong seat, the bcm, apim, and srs would code faults because each buckle had different identifications!
Can bus is not sending just voltages through wires, its sending information as well!
NJBob
New Jersey
Thank you, was wondering if each item on the bus has its own address. Meaning one wire runs all over the car and each has its own address. But sounds like each item goes back to the computer and it must monitor current draw.
lesnav
Lester
XLT Hybrid Lux 360
My lasfits still hyperflash. So, there's that.
oh mine too, I thought they aren't suppose to hyper flash. I'm kinda' disappointed about it...
