Nothing personal, Auto Hold just doesnât seem to explain whatâs going on here. Itâs a good thought nonetheless.OK, guys. I understand that's how it is SUPPOSED to work, but I also believe that Ford did not INTEND for the brakes to be grabby at all. I was just trying to share a work-around that appears to prevent the "grabby brakes" in my Maverick. Since I started turning OFF the AutoHold, I've experienced it exactly zero times. Prior to turning it off, I got it fairly often.
The correlation isn't strong enough to equate to "causation" in my mind, but it seems to be related somehow. Since ALL the braking is computer controlled, and since we're talking about very low speeds here, I was suspicious that one of the sensors in that system might be off calibration slightly, causing AutoHold to engage before it is supposed to do so.
IF that were the case, it could explain both the symptoms I've experienced (grabby brakes at very low speed with AutoHold turned ON), and the reduction in those symptoms when I turned AutoHold OFF.
I'll shut up now, so no need to tell me yet again how wrong I am. For those who can't get in to your service department right away, you might just try this and see if it helps YOUR situation. Perhaps a long shot, but at least for my Maverick it seems to have helped.
Below 6.2 mph (10 km/h) is when the vehicle begins to switch over to friction braking from blended friction and regenerative braking.
With light braking, not only are you not using friction braking above that point (youâre well within the limits of regen), below that point, it needs to start applying the friction brakes to provide seamless continuous braking. That itself can be tricky to get right - applying just the right pressure through the calipers onto the brake disks that you hardly realize anything happened.
Ford seems to have admitted that they havenât made this process as seamless as it should be. Sounds like itâs simply applying more friction braking than it was previously applying regen, thus a noticeable increase in braking action (âgrabby brakesâ).
Of note, harder braking at higher speeds that requires a blend of regen and friction braking helps to mask the point where friction braking is blended in. That's because you have more speed to work with, and you're already braking hard. When you're moving slowly, and braking very gently, any jumps in braking action are much more noticeable.
