- Banned
DIY Grabby Brakes Fix
I swear this works for me.
For at least 15 out of 15 days.
When able, when safe, as soon as possible on your first drive of the day, get up to 25 or 30 mph, look behind you, then BRAKE FIRMLY. No need to screech the tires or evoke ABS. Brake briskly enough to exceed regen, and get about 50% hydraulic braking power. Continue strong braking until you stop. That's it. As an alternative, shift to N and do your first stop of the day in N.
I will not feel "grabby" brakes no matter how many times I try after doing this.
I live in a coastal area (SF Bay) with fog and dew most mornings. I feel heating the brakes, drying the brakes, shedding surface rust, whatever helps in my scenario. Can't be a fluke if it worked 15 times in a row, right?
I can't prove dampness is a root cause. MAYBE the dumb truck needs to "learn" something from that first application of hydraulic brakes. Stupid if that's it because it "forgets" overnight.
Do it safely. Pay attention to who if anyone is behind you.
Try it and report back if this helps your Maverick.
I agree Ford needs a permanent remedy.
Sounds like they are working on it. Please TRY this and see if it helps you, before the Ford update comes out.
15 out of 15 for me.
Not proof of anything.
But I'm batting 1000.
