Truck Bed Port
myroncoxe
Myron
Newnan,Ga
2025 Maverick XLT
What is the 12 V DC Flexbed port for? Thanks
Ford Maverick Truck Bed Port IMG_1503
It's where the 12v wire that came loose with your truck can be plugged in to get (20 amp fused) tap which will stay hot if itbhas something using current.
myroncoxe
Myron
Newnan,Ga
2025 Maverick XLT
Thanks, do you have an example of something you have used it to power?
RideSolo
Cory
North Central Ohio
Dad
Good variety of 12v accessories you can install using those ports from USB chargers to cigarette lighter style outlets. Besides Etsy, Amazon has many vendors, too. Many threads here on what others have done.
Tailender
Will
Poconos
This is what I installed in my 2022. Putting another one in my 2025. The switch was for lights I put in the bed. 12v outlet was good for running my livewell for fishing.
Ford Maverick Truck Bed Port 1085
piwtrnr
Union City PA
Where did you get it and how is it held in there?
myroncoxe
Myron
Newnan,Ga
2025 Maverick XLT
So on the 120V AC plug has anybody found a good use for it? My power is out so tried to use it for a coffee pot but guess the pot draws too much, it kept tripping off.
Tailender
Will
Poconos
I got it off ebay. I used a 1 1/8" paddle bit to drill the holes to fit the switches-plugs. They each have a lock ring on the back side that I tightened down and that holds the plate in place, no screws needed. You do have to be careful to center the drill hole in the plate holes.
Carlitos_92
piwtrnr
Union City PA
Thanks
ZABSMAV
Utah
2023 Maverick Lariat Hybrid
If this is tied to the terribly undersized and inadequately charged battery under the back seat, you put a 20amp load on it and you will get about an hour out of the battery before its dead, since the Maverick charging system only charges that battery to a 50% SOC.
I believe that circuit is the one that stays on for 90 minutes or until the 12v soc drops to 12.1 volts. So the battery save function would continue to operate same as it does currently. No difference just would still be recommended to put truck into ready state when using battery.
