Trickle charger unable to charge 12v battery?
AutobahnSHO
Will
S.Carolina
Maverick, Miata
Weird since there's no reason why these apps should be running/doing anything in the background.
Whether someone uses the Ford app or not, Mavericks have a cellphone built into them. It's talking with Ford whenever it wants, and ALWAYS listening for an app notification to start- unless those can/are turned off in the menus.
chilicoke
chilicoke
S2000
Yes I'm aware of that, but @Ringo's dealer suggested simply delete the app not disable it from the car, and if it truly makes a difference that having the app installed is doing more polling/communicating in the background than it needs to.
I just took a look at my April-May FordPass data usage and it seems like it used more background data then foreground.
Ford Maverick Trickle charger unable to charge 12v battery? Screenshot_20230527-075425
I'll probably do some experiments to see of my Google Assistant linked commands still works if I completely disable background data, and what else works/does not.
I think the stock 12 v battery that shipped with the truck is crap.
Turn off the key, one minute later, it reads 12.4 volts. 5 minutes later, it reads 12.2 volts. Park the truck overnight, everything off, next day; it's in the high 11.x volts.
I'm seeing the exact samething after a few days of monitoring. 14.3v when truck is on, turn it off drops to 12.5 right away and down to low 12 after just an hour. A well functioning battery should hold 13.5v easily for days or weeks.
VBLariat
SE GA
22 Maverick Lariat
Please let us know if you can still use Google commands with the Ford pass app deleted.
chilicoke
chilicoke
S2000
I highly doubt it since Google Assistant fowards the command to reasonable apps in cause of FordPass and MyQ for example.
But stuff like background data usage is most likely for notifications like deep sleep warning, which ironically most likely caused it. 😅
I would think that there must a device agnostic web-API that Google could/is using since you can also do the commands via smart devices (Echo, Google Home) that wouldn't have a FordPass app running.
chilicoke
chilicoke
S2000
Actually the full FordPass Google Assistant command is "ask FordPass to start my vehicle with pin xxxx" since the app isn't fully integrated into Assistant. It's just too much to say so I created a routine so I just have to say "start my car" and let Assistant issue the full command silently.
I haven't really tested it on my smart devices since my phone is always with me and responds faster
Old Ranchero
CO
Trickle Charger aka "Battery Maintainer". Only designed to keep a healthy battery topped off when extended periods of inactivity planned. This is substitute for disconnecting your battery so you don't lose memory settings on everything. Not designed/intended to bring a dead or weak battery back up to fully charged.
Basically the same procedure for running it through Alexa. I use the same routine command verbatim. Doing it through Amazon services required some authentication steps so maybe that's the difference between allowing access to a global API versus a phone Google Assistant just hooking the app command locally.
I use this good for up to 120AH. NOCO GENIUS5: $69.95
Meet the GENIUS5, one of our most powerful, highest-performing, energy-efficient, and compact portable universal battery chargers yet. The GENIUS5 is a 5-amp (75-watt) - 100-240VAC 50-60Hz - 6-volt and 12-volt heavy-duty battery charger, battery maintainer, trickle charger, float charger, and battery desulfator for up to 120 amp-hours. It's designed to charge and maintain all types of sealed lead-acid and lithium-ion (lifepo4) batteries, including flooded, gel, maintenance-free, AGM, SLA, VRLA, as well as automotive, marine, RV, powersports, and deep-cycle batteries. Its advanced battery repair regenerator mode uses slow pulse reconditioner technology to automatically detect battery sulfation and acid stratification, restoring lost battery performance for extended battery life. It can be used and stored almost anywhere - home, garage, mobile, bench, or in car - to charge and maintain any battery - even plug in through your vehicle's 12V auxiliary cigarette lighter port. Its next-generation charging regime utilizes fast charging microprocessor technology to rapidly recharge batteries without any manual intervention. It's a completely automatic, worry-free, professional, and commercial-grade intelligent battery charger with zero overcharge. Designed to be dual purpose - both indoors and outdoors - providing weatherproof and waterproof protection from the outside elements during any time of the year, including winter. Its X-Connect battery connectors - better than SAE - allow for quick-connect permanent connection or connecting directly to the battery terminals. A digital display provides the charging status and tests diagnostics for multiple conditions such as a dead battery, bad battery, reverse polarity, and more. And it's compatible with all types of gas and diesel vehicles, including cars, automobiles, motorcycles, dirt bikes, scooters, mopeds, lawn mowers, ATVs, UTVs, lawn tractors, trailers, trucks, SUVs, boats, campers, RVs, jet skis, PWCs, wave runners, snowmobiles, 4-wheelers, generators, golf carts, classic cars, including BMW, Mercedes-Benz, Porsche, Bentley, Maserati, Lexus, VW, Audi, Ford, Chevrolet, Corvette, Cadillac, Jeep, Prius, Toyota, Subaru, Nissan, Honda, Harley-Davidson, Suzuki, Yamaha, Kawasaki, Ducati, KTM, Indian, Husqvarna, Vespa, Polaris, Seadoo, John Deere and more.
