Travel trailers for the hybrid
Probity
Covington LA
'24 Silverado CCSB 2.7 (a Mav. Hybrid next time?)
I'm curious so I have to ask. When figuring out frontal area drag for towing would you combine the area of the Maverick and your trailer for the total? I would think that because the Maverick is already pushing air with it's frontal area that frontal area being added by the trailer would dramatically less than the actual area of the trailer. Does that make sense? I would think the actual area of the trailer contributing to the overall drag would less because the Maverick is already "blocking" 20 Sq ft of it.
My frontal area understanding (post #79): (21) 2022 Maverick Trailer Towing & GVWR / GCWR Guide | Page 6 | MaverickTruckClub.com - 2022+ Ford Maverick Pickup Forum, News, Info
STARCOMMTREY1
Trey
Boligee, AL
You have seen that they are not building FWD w/4K towing, right?
You will have to update to AWD.
Make sure it has electric brakes. If not install them immediately
cnp1234
Honda Ridgeline
I thought this might be neat but it's really at the limit of what you can do with the hybrid: https://aliner.com/campers/lxe/. Probably tough to keep it under 2k lbs with water, gear, etc, but at least it's got a low frontal area and is hard shell all around. Not sure if the frontal area is quite small enough.
koolkats3
LuAnn
madison wi
2015 vw passat
Was hoping to get by with the 2.0 hybrid and the 2k towing package. MPG is really important to us. Thanks again.
koolkats3
LuAnn
madison wi
2015 vw passat
Was hoping to get by with the hybrid and the 2k towing package. MPG is really important to us. Thanks again.
Probity
Covington LA
SgtLip
Donald
Disney World
We have ordered the 2.0 ecoboost FWD with 4k tow. We are going to be pulling this awesome little trailer 14BH:
https://travelliterv.com/rvs/2021-rove-lite-travel-trailers/
Hitch Weight
185
Hitch Height
17"
GVWR
2,500 lbs
UVW
1,850 lbs
Cargo Carrying Capacity
650 lbs
Exterior Length
16'6"
Exterior Height
8'1"
Exterior Width Body
6'6"
Exterior Width Body w/Awning
7'1"
Exterior Width w/Wheel Wells
7'11"
I like it, thanks for sharing that one. I hadn't run across this brand.
sseiler
TN
RAV 4 XSE
Anyone planning on getting the hybrid and planning on towing a small trailer with it? Please share what you intend to tow?
I don't have one yet but I see this Jayco 12SRK that looks like it might be doable as long as you don't load it down too much with gear.
https://www.jayco.com/products/travel-trailers/2021-jay-feather-micro/12srk/
Man, I think you’re on to something here. I really dig this trailer. I think you’re right, too, as long as you’re not loading it down, it should be fine, although it’d be hitting the upper limited of its towing capacity.
fbov
Frank
Bushnell's Basin
2020 Escape Hybrid
Yes, it does, until you look at wind tunnel flow and understand that most of the drag comes from the back end. Adding a trailer typically makes things worse. I did a "tuft test" with the C-Max, that shows the range from smooth/laminar flow to turbulent/high-drag flow. The rear roof corners show the start of trailing vortices
Sitting several feet behind the bumper, the trailer is a completely separate aerodynamic object. Bridging the gap between car and trailer would greatly reduce total drag, but it's not trivial.
BoomerBoy
Royal Oak, MI
2010 Ford Focus SE
A 5x8 enclosed cargo trailer is the largest that I'd tow.
I like to follow the 80% rule-of-thumb when towing. That is, don't exceed 80% of the vehicle's weight-carrying tow capacity. The hybrid is rated for 2,000lbs, so 80% would be 1,600lbs. That trailer empty is 1,600lbs and its gross exceeds the 2,000lb capacity.
However, it also depends on where you're towing. If you live in Florida or west Texas (AKA, where it's flat) and/or you don't mind going slowly (like, 30mph) up mountain passes, then I wouldn't have a problem towing that trailer.
I tow 4,000lbs over the Grapevine Pass in central/southern California with my Nissan Frontier a couple times a year. The truck can drag that trailer up at 55-60mph with power to spare, but it's doing near redline for miles. I prefer to duck behind a semi and go up at 30mph at about 2,500RPM.
I found a uhaul 5x8 enclosed trailer total empty weight is 900lbs leaving 1100lbs of cargo to haul. Good for small moves!
casanewt
Cincinnati
2023 KIA Sportage X-Line Prestige PHEV
So I was looking up hybrid towing videos and found a couple of RAV4 Hybrid towing videos from Alex on Autos. This is not quite apples to apples, but Toyota's hybrid system is very similar to Ford's.
