wax87
Stuart
Dallas South
2004 Avalon
I'm posting this in the maintenance section rather than the transmission section because it's the servicing instructions for the transmission on the EcoBoosts. The revision of the service manual is 2021 so unless something drastic changes, it should remain current for a while for the 8F35's. If something does change and someone informs me of it, I will update the post accordingly.
I'll start with the how to fluid level check procedure:
The rest of the procedure for the fluid exchange is the same as the fluid level check.
Now the drain and refill procedure:
Pretty simple procedure. I'm sure you can skip the step that calls for using something like Torque to monitor the TFT PID (temperature), but it does need to remain at operating temperature during the procedure.
Hope this helps.
Do you have this for the Hybrid tranny?
billbillw
Metro Atlanta
'23 Maverick Lariat FX4
Not sure if it was mentioned previously in this thread, but RockAuto stocks the 5qt jug of the recommended Mercon ULV. Search using XT125QULV, priced at only $24.79 currently. Even with shipping, this is probably way cheaper than buying individual quarts from a local store or dealer. I'm just approaching 24,000 miles and I bought all the fluids for the transmission, PTU and RDU. It was just over $90 for everything shipped.
307-01AÂ Automatic Transmission - Automatic Transmission HF45 2022 Maverick
General Procedures Procedure revision date: 07/30/2021
Transmission Fluid Level Check
Materials
Name Specification
Motorcraft® MERCON® ULV Automatic Transmission Fluid
XT-12-QULV
WSS-M2C949-A,
MERCON® ULV
Â
Check
1. Start the engine and allow to run for 1 minute. Turn engine off and wait 5 minutes.
2. With the vehicle in NEUTRAL, position it on a hoist.
Refer to: Jacking and Lifting (100-02 Jacking and Lifting, Description and Operation).
3. Remove the screws and the engine front undershield.
Ford Maverick Transmission fluid check and service, with torque specs (per the Service Manual) 1765337867820-93
4. Rotate the steering wheel counter clockwise to access the transmission fluid leveling plug.
Ford Maverick Transmission fluid check and service, with torque specs (per the Service Manual) 1765337912349-4h
5. NOTE: The transmission fluid should be even with the bottom of the transmission fluid leveling plug hole.
Remove the transmission fluid leveling plug and check the transmission fluid level.
Ford Maverick Transmission fluid check and service, with torque specs (per the Service Manual) 1765337974118-g6
Adding Additional Transmission Fluid
NOTE: The following procedure uses the Mityvac MVA7212 ATF Refill System.
6. Install the adapter into transmission fluid leveling plug hole hand tight.
7. Fill the transmission with transmission fluid.
1. Fill the Mityvac MVA7212 with transmission fluid.
Material: Motorcraft® MERCON® ULV Automatic Transmission Fluid / XT-12-QULV (WSS-M2C949-A, ) (MERCON® ULV)​
2. Connect the Mityvac MVA7212.
3. Follow the manufacturer instructions to dispense the fluid into the transmission.​
8. Release the pressure and remove the Mityvac MVA7212. Allow all excess fluid to drain into a pan.
9. Install the transmission fluid leveling plug.
Torque: 26 lb.ft (35 Nm)
Ford Maverick Transmission fluid check and service, with torque specs (per the Service Manual) 1765338055595-4n
10. Install the engine front undershield and the screws.
Ford Maverick Transmission fluid check and service, with torque specs (per the Service Manual) 1765338111114-7c
To change ain't much different.
Step 5.5 (to confirm refill plug can be removed) - remove drain plug on bottom of pan, drain fluid. Install drain plug. Torque: 124 lb.in (14 Nm)
Repeat step 1.
Proceed step 6.
wax87
Stuart
Dallas South
2004 Avalon
Materials
NameSpecification
XT-12-QULV
WSS-M2C949-A,
MERCON® ULV
Â
Check
1. Fill the Mityvac MVA7212 with transmission fluid.​
2. Connect the Mityvac MVA7212.​
Repeat step 1.
Proceed step 6.
thank you
