Transmission cooler
Azmig88
Ted
2022 Ford Maverick 2.0 Lariat
I have a 2022 NON FX4 Lariat without the tow package. I see I have a 2nd smaller “radiator” in front of the radiator. There’s also an oil cooler assembly with hoses going to the transmission and the 2nd smaller radiator.
This is a trans cooler, isn’t it??
The reason for the question, is as I understood, a trans cooler only came with the tow package, and maybe the FX4. I have neither.
Any comments?
Thanks
MinntoMich
Erick
Minnesota
S10, Renegade, Impala
What else could it be? It won't be a PS cooler.
No option 53Q for you then means maybe someone with a tow package thinks they have a cooler and they don't.
Consider it a bonus if you have one and didn't opt for it.
Maverickman74
Shane
Maui HI
I think they just get bigger?
commadorebob
Air conditioner?
Azmig88
Ted
The Ford part# JX6Z 7869e
It says “Transmission oil cooler”
Here it is:
Ford Maverick Transmission cooler 1693414311147
Here is mine:
Ford Maverick Transmission cooler 1693423271651
LC48
Johnson County Texas
My non-tow XLT has one as well. Consensus some time ago was the tow package gets a larger cooler, different PN...
Azmig88
Ted
It is a trans cooler. I recently had service. A Ford Master mechanic confirmed that’s what it is.
I’m virtually positive that this was not standard equipment on a Non FX4/Non tow package Lariat.
I’m very happy to have discovered this. I was going to pay to have all this added.
Cigargoyle
Denver NC
2022 Maverick FX4K
That would be the standard trans cooler . Tow package has a secondary/larger cooler.
Azmig88
Ted
I believe you and I KNOW that I don’t know.
Having said that, I only found one part number for a trans cooler.
Can you find two different part numbers?
Please understand: I’m not debating you. Honestly, I think I’m probably wrong and you’re probably right. I’m just hoping it’s the other way around 😀🤞
Azmig88
Ted
From Ford’s website​
Ford Maverick Transmission cooler 1695995045104
Cigargoyle
Denver NC
2022 Maverick FX4K
JX6Z7869C - Trans cooler without tow package (under truck, side of trans)
LX6Z7A095A - Trans cooler with tow package (front of truck, radiator area)
Azmig88
Ted
I saw that same thing earlier and thought the same thing.
Google those numbers and look at the pictures
One is for the cooler
The other one is for the 2nd “radiator”
LC48
Both PN's are trans coolers. Tow pack one is higher capacity, likely named differently to save tech confusion.
Cigargoyle
Denver NC
2022 Maverick FX4K
According to this, this is the tow package cooler.
Ford Maverick Transmission cooler Screenshot_20230929_101612_Chrom
