Aftermarket trans cooler
Status
Not open for further replies.
Fast Mavericks
Ivan
2023 Lariat Eco AWD
Ford Maverick Aftermarket trans cooler F6302760-95F4-459A-B385-B24B5F7F40E7
I just had to change my Trans Range sensor and while the front was apart I swapped out the 4k cooler for a Trucool 40k with -6 lines. The factory cooler is sandwiched between the radiator and AC condenser so I mounted this up front.
I’m still putting it back together but I’m hoping this will keep the temp in check as I was seeing 230 during spirited driving.
I’ll keep you updated on the results.
Hardening2753
Ford Maverick Hybrid
Any updates? I love seeing your threads and what you are up to
Fast Mavericks
Fast Mavericks
Ivan
2023 Lariat Eco AWD
Hardening2753
TORQUERULES
Ford
Any codes after removing the active grille shutters louvers?
Status
