TPMS Relearn / Reset?
Formula11
Nj
XL AWD AREA51
I will try to inflate it to 37psi before the drive this morning then.
Inflate to 37psi than use the key brake method and the tpms tool should work
rth121
Monterey
2022 Ford Maverick XL
Interestingly... The tpms light is off and now it's reading the sensors - though I still question it's accuracy or if it's syncing correctly still.
This morning I went around and inflated all the tires to around 36.5-37.0 psi per the air pump; but that could be off...
The TPMS readings have not changed at all since this morning and still showing the following: 34psi front left; 33psi front right; 33psi rear left; 35psi rear right
I might try to inflate it a little higher tomorrow morning to see if it increases from those psi.
Did you drive it afterwards? The TPMS system usually doesn't start polling the sensors until you get up to 15-20mph.
rth121
Monterey
Yes, I drove it 5 min after inflating the tires. My trip to work was roughly 20 minute. Same psi reading on the way home from work.
rth121
Monterey
Update - went to two local tire shops this morning, neither was able to sync it up with the Maverick. They put the vehicle in training mode (brake / key method) and attempted to activate the sensors - no response from the vehicle.
I'm a little defeated at this point. Either pay up and get new sensors again or just drive without TPMS.
mikeakasully
Wisconsin USA
2010 Ford Escape, 2023 Ford Maverick 2.0 Ecoboost
I've used the brake and key method on a few Ford vehicles including my Mav with the official Motorcraft tool and never had a problem. Just rotated the tires and it worked great.
JP4AZ
Phoenix
For what it is worth. I have the motorcraft sensors (from Ebay) in my truck. I did not have to do any relearning or anything. the truck learned them by itself. The pressure reading is about 2 lbs lower than my old tire gauge, but all are recognized and working.
rth121
Monterey
I ended up returning the Mobiletron Moresensors I purchased and having a local tire shop swap the oem sensors to the new wheels + tires. Was going to sell the steelies with the tpms in them for the next owners, but now the steelies are up for grabs without tpms.
surfstar
2023 XL Hybrid
Wow, good info and thanks for the update.
This weekend I'm picking up some Bronco Sport wheels and tires that should be take-offs with OEM TPMS in them. I thought I'd have to buy the reset tool, but it sounds like they may just relearn/update after I put them on. Fingers crossed...
Lou'sBluMav
Lou
Upstate SC
2004 Chevy Colorado(sold Oct) 2018 Subaru Forester
I have a '23 Mav XLT hybrid. Mounted Michelins at ~400 miles on original rims. 7500 rotation yesterday. Today I performed the flasher/ release air method and it worked first time. No need for a TMPS tool.
EONR24
United States
2024 Ford Maverick XL
Relearn Procedure
1. Turn the ignition switch to the OFF position. Then, press and release the brake pedal.
2. Cycle the ignition switch from the OFF position to the RUN position three times, ending in the RUN position.
3. Press and release the brake pedal.
4. Turn the ignition switch to the OFF position.
5. Turn the ignition switch from the OFF position to the RUN position three times, ending in the RUN position. The horn will sound once and the indicator will flash if the training mode has been entered successfully. If equipped, the message center will display “TRAIN LF TIRE.”
6. It may take up to six seconds to activate a tire pressure sensor. Do not wait more than two minutes between training each sensor or the process will time out and the entire procedure must be repeated.
7. Starting with the left side/drivers front tire, press and release the test button on the TPMS tool. The horn will sound briefly to indicate that the tire pressure sensor has been recognized by the vehicle.
8. Within two minutes of the horn sounding, repeat the process with the right front tire pressure sensor.
9. Repeat these steps for the right rear and then left rear tires.
10. The procedure is completed after the last tire has been trained. When the training procedure is complete, the message center (if equipped) will display “TIRE TRAINING COMPLETE.”
THIS POST NEEDS ITS ON STICKY !!
EONR24
United States
Hey so I just put on new wheels and tires with brand new TPMS sensors. And it seems like they just work without any relearn necessary. Have others experienced the new TPMS sensors just working straight out of the box?
NY Mav
St James New York
2023 XLT Maverick
what sensors brand did you buy?
Don806
Don
SE Ohio
I thought that was the case also when I swapped rims/tires for the winter...........but turns out it's not the case, at least with my Maverick. I have to have the truck re-learn the TPMS even when I do tire rotations, to let the truck know what TPMS is where on the truck. last rotation, we let the air out of the right front, and the dash showed the low tire on the right rear.
