Tire pressure info after rotation. TPM Sensors
MaverickShark
Sal
San Jose, CA
Maverick XLT Hybrid 2022 Mitsubishi Outlander 2017
I recently hit the 10k mile mark and decided to rotate the tires on my own. After moving them to their new positions I checked the dash info screen to check the pressures. Knowing that one tire had a slightly higher pressure than the others, due to having to patch twice already, the screen showed that the tires had not moved. Is there a way to move the tires (TPMs) on the dash info screen using the steering wheel controls or do I need a diagnostic/programing tool to do this?
jsus
2022 Ford Escape Hybrid AWD
How far did you drive after you rotated the tires? Typically it's supposed to pick them up automatically in their new positions.
Decayed
yes
a car
I thought you needed a tool to set the new position.
Johnkn
MD
The truck should recognize new positions after a few driving cycles...
MaverickShark
MaverickShark
Sal
San Jose, CA
You are right. Did about a 20 mile round trip and they automatically switched to new places.
Mymaverick2021
Steveo
Hilo Hi
First off your supposed to rotate your tires every 5000 miles and you a TPMS reset tool from Amazon for like 15 to 20 bucks
OXHB619
Clayton
XL EB 2.0
Ford says 10k
I checked Michelin web site and the Ford OEM primacy that's on maverick shows 4-6k rotation OR when uneven tread wear is noticed so could be less than 4, I suppose. Mine were off about 0.6/32" at 7300 miles then at next rotation at 14,500 miles tread remaining were within 0.1/32". 65k warranty is down to 2/32" though I usually replace at 4/32". My quick lane recommends at 6/32" but with primacy OEM's born with 8.5/32" that's tough. I may go with 75k generals altimax rt45's that come with 11/32" but they weigh 26lb for 225's and 28lb for 235's (29.1" diameter also).
Dubhlaine
Maverick XLT
As i understand we don't need any tool for the Mav. But you do need to drive to actually cause the TMPS sensors to 'switch on' a centrifugal switch saves the sensor battery when not been driven.
So until you drive the sensors will not turn on. Each wheel location has a receiver to pick up that location so no need to put in learn mode either...
Carlitos_92
Ford Maverick Tire pressure info after rotation. TPM Sensors 1736430572240-2s
