This is a full size spare?
Saltwater Cowboys
Josh
ENC
09 Ram 1500, 23 CG XTL Lux, 24 SB Lariat BAP
WTF?
Ford Maverick This is a full size spare? IMG_2724
uga
SE USA
2026 Ford Maverick XLT
There is no Full Size Spare from Ford, check the placard on your drivers side door jam.
They label it that, but doesn't seem too much better than a doughnut spare. The size doesn't match any trim levels factory tire size from what I understand on this forum. I always heard to never run different size tires on the same axle (not that any of this gospel).
LSchicago
Lloyd
IL
Full sized, not same size.
Saltwater Cowboys
Saltwater Cowboys
Josh
ENC
Well I'm 500 miles from home so it'll have to do. Doubt the mismatched wheel thing matters much for a rear wheel on a hybrid though.
Saltwater Cowboys
Saltwater Cowboys
Josh
ENC
Compared to the RAM the Maverick is a full size spare vehicle.
Something must have changed then. My 2009 Ram had a real spare. Same size as the other tires. Still had air in it after 12 years too and got me halfway to Indiana and all the way back towing a 7000 lb camper.
badMotorist
Ted
'01 Grand Marquis LS
Also consider the space constraints that might be under the Maverick compared to a Ram. You need a deep enough cavity to fit a spare without it sticking past the body work or rest of the undercarriage.
Clarkdonbran
cyberdog
Ray
2023 Maverick Lariat Hybrid
Depends on your definition of 'Full Sized Spare'. Ford apparently means it's not a temporary spare (donut), with a 50 mph or 50 mile limitation.
The rim will not match, and the tire will still be slightly undersized. Wishful thinking would be along the lines it would be a perfect match to the other four tires, which sadly isn't the case. - Explains how the Hybrid comes with a 'full sized spare' at no charge.
