Third Tailgate Position?
3JB
2026 Ford Maverick
I am familiar with the two tailgate positions officially provided by Ford.
Ford Maverick Third Tailgate Position? IMG_1949
Ford Maverick Third Tailgate Position? IMG_1950
But looking at the provided arrangement, it seems that there is a third position that might work. This is what I found:
Ford Maverick Third Tailgate Position? IMG_1954
Ford Maverick Third Tailgate Position? IMG_1951
The standard connection point for regular tailgate operation has a wheel with a groove - about the same size as the tailgate cable. Looped in like this, it seems to be "home". I drove it around town for a while without a load on it and it held beautifully. I like that it allows a long load (just a few 2X4's, or in my case, a pole mounted lopper) to be held up a little higher without having to open up the bed cover.
What I don't know is if this is some kind of specific no-no from Ford, or if anyone has tried it with bad results.
Tbone289
My only thought about it is that, if the load on the tailgate is light and the tailgate is allowed to "bounce", the cables could slip out of the grooves causing the tailgate (and load) to slam down to the fully open position. I don't think it's likely that would happen, but it's possible.
3JB
2026 Ford Maverick
I had that concern too - still do. But my test drive, with almost no load on, resulted in no suggestion that that might happen. The cable seems to set itself inside the tracks of the "bed flat" attachment point. I thought "Oh, great, now it's gonna get stuck". but, no, it just seems to settle in and comes right back out.
FWIW, in this position, if it slips out and falls, the tailgate is in the tilted position - not flat
Tbone289
Good points. It will be more secure if the cable "seats" into the groove, and of course it will only fall to position "2", not fully open as I stated above, which should minimize damage in the rare event that they slip out.
Redline
Upstate, NY
I'm familiar with that configuration. I've used it, like you said, to haul lumber. I don't recall exactly when, but I saw that position demonstrated in a video. With some weight on it, I doubt the cables would slip off. I consider it a viable option. 😬
3JB
2026 Ford Maverick
I'm familiar with that configuration. I've used it, like you, to haul lumber. I don't recall exactly when, but I saw that position demonstrated in a video. With some weight on it, I doubt the cables would slip off. I consider it a viable option. 😬
Good to hear! Thanks!
3JB
2026 Ford Maverick
What if you leave it connected to the bottom and loop it over the top?
I don't think I would want to do that. The cable itself doesn't seem to want to "lay straight", and has several bends in it. More of concern is the top connector is long and skinnier, putting more moment force on it and could break. The way I am doing it, the cable stays right up against the body of the truck.
Ford Maverick Third Tailgate Position? IMG_1955
Ford Maverick Third Tailgate Position? IMG_1956
scottjl
Midwest USA
'25 Lariat Eruption Green, 4k, BAP
nice to have options, i'd have a concern if there was some sort of damage and ford found out you were using it in an "unsupported" position.
maybe some 3rd party will release shorter cables that can be swapped in and have the same result.
3JB
2026 Ford Maverick
I hear you. I'm not thinking I would use this option on a frequent basis, at all. Just another tool in the toolbox - never know when you might need it!
And there is always the old "My goodness! HOW did that cable get wrapped around that connector like that?!?"
Mavster Mechanic
Hybrid
The hood prop rod has two options as well. Normal, and one for extra tall people.
Unofficial hack, like here.
There is the slotted hole in the hood you all know about.
There is a square hole near the passenger side hinge that makes the prop rod hold the hood open more.
Works well. I use them both interchangeably.
Chops
Lobo
That hole you are using is not meant to hold the prop rod. Use it at your own risk…
Mavster Mechanic
Hybrid
I said hack. Less risky IMHO than the tailgate hacks. Both are low risk.
I think use of the square prop rod hole is more secure than the slotted one. It's sometimes a little difficult to get the rod back out without some effort. I'd want to use the unofficial one in windy conditions. Less chance of slamming on me. (But I don't often (or ever) do engine work in windy conductions, but I like, and sometimes need the extra headroom. )
Cancunbadlands
Cancun
Cancun
My only concern is the possibility of a bouncy cable
SilverBullet2.0
Josh
2025 Ford Maverick Lobo
Now there are 4 positions!
