Tailgate won't open - help!
RZ Lee
Lee
Oregon IL
23 XLT
Last week I was loading up my MAV for a trip. I closed the tailgate and.......that's the last time I've been able to open it.
I've tried unlocking it - with the fob, the button, and the key. All nothing. I've tried pulling, pounding, and prying. I have a tonneau cover on so I had to rig up some zip ties to be able to open it and get stuff in/out of the best.
I assume there is either a cable or rod system inside the tailgate that opens latches on each side of the bed. I've not tried yet - can the inner panel on the bed side of the tailgate be opened up to access the latch mechanism? Does anyone have pictures or a video of what's inside?
Since I was packed for a trip I didn't have time to dig into it more before I left. Looking for previous experience and advice to see what I need to get into to fix it.
I guess it's better that it's stuck closed vs. open?!
Thanks, Lee
dalola
Retired
SE Ohio 🇺🇸
I recall a similar post here a while back of this same problem. If my memory is correct (unlikely!), the lock rod inside the T/G had come undone. You can access it from the panel on the inside of the T/G.
FamousAmos
GAB
Maryland
2022 Maverick Hybrid XL
This.
Just let the dealer fix it if it's still under warranty.
Yes. Better the dealer attend to it than you. If you try and don't succeed, he can blame it on something YOU did, and not cover it under the warranty.
Maverick2023
Kip
Atlanta, GA
Toyota Rav4
I had this happened once and had to remove the panel to access the locking mechanism. The rod got loose and it wouldn’t lock. I had to duct tape them back in place.
RedRider
Kitchener, Ontario, Canada
Why didn't you get it repaired under warranty?
Tim d
Alpena
Ram
You don't h
Thanks, Lee
you don't have to worry about fixing it....Ford does.
Maverick2023
Kip
Atlanta, GA
Toyota Rav4
It wasn’t broken just the tabs that holding the rods in place came loose when I installed the power lock. It’s the poor quality of parts. You can replace the tabs but it still gonna come loose later. At least I know what the issue is if it happens again down the road later.
TheSEARCH
ford
It does bring up a question about warranty repair. He said he has a cover on back like I do. Mine is a tri fold hard cover. Not sure if OP has the same. I would think the owner is responsible for getting that cover open FIRST. Would he not as it isn't factory. Plus they may just break it open.
I guess I could get mine open? Lucky I don't have this problem. Get a coat hanger inside to pull cable release I guess?
Rexus99
Michael
Mountain West
2007 Tacoma
Re-read, He got his tonneau cover open.
TheSEARCH
ford
No I saw that I was thinking if it happens to me or another Mav owner. The owner would have to get the cover opened before bringing to dealer? .
