Wisconsin Tailgate Tie Down Bracket, Clears Tailgate Assist Strut
Lane
Lane
Central Wisconsin
photos.app.goo.gl
--> $20 for one bracket, $35 for two. Add $5 flat shipping for whatever you buy (see my signature at the bottom of this message for the other things I make).
Like many here, I added a tailgate strut and then the tailgate won't close with the stock tiedown bracket in place. So I made one out of scrap metal I had in a bin and posted it in my build thread here, and others asked if I'd be interested in making a few more. I have a few of these available.
Ford Maverick Tailgate Tie Down Bracket, Clears Tailgate Assist Strut BRACKET 1 SM
Ford Maverick Tailgate Tie Down Bracket, Clears Tailgate Assist Strut BRACKET 2 SM
The steel is thicker than it needs to be, 1/8". Cut, bent, drilled & chamfered, corners radiused, welded, sanded, and powdercoated in either of two finishes for $20 each. Add $5 for a flat shipping cost and that covers anything else that you may want to purchase at the same time as well (see my signature for the other items I make & offer.
On my truck, I have the factory Ford spray-in bedliner which DOES NOT get sprayed on the gate surface where the bracket mounts.
Ford Maverick Tailgate Tie Down Bracket, Clears Tailgate Assist Strut bedliner1
I use my truck and this configuration as a drilling template for the bracket's bolt holes. They are pretty exact and they don't offer much wiggle room. Each bracket is fitted to my gate as I build it to be certain the fit is right.
Some companies offering aftermarket spray-in bedliners remove the brackets first, and then spray the liner. If the liner isn't sprayed too thick in that area, my bracket has good odds of fitting over it without issue.
Ford Maverick Tailgate Tie Down Bracket, Clears Tailgate Assist Strut bedliner4
But if it's sprayed thick in that location, you may have to make some adjustments for it to fit. That may include masking the area of the bracket's top footprint and using coarse sandpaper to remove some of the bedliner's texture/thickness in that area. You can also drill the bracket's lower hole one size larger, or elongate it with a rotary tool.
If you have a drop-in bedliner - the placement and angle of the loop on the bracket allow enough space between the bed side and the loop when the gate is closed to accommodate the thickness of the bedliner on that side wall. On the gate itself, the bracket cannot be mounted over the top of the plastic liner due to its thickness. When the bracket is mounted to the gate, the side of the gate's plastic liner will butt right up against the loop in most cases with no issue. It is often a pretty tight fit though.
Ford Maverick Tailgate Tie Down Bracket, Clears Tailgate Assist Strut bedliner2
In some cases, owners have wanted more space around the loop or didn't want as tight of a fit against it and have chosen to slightly notch the gate liner's plastic around the bracket.
Ford Maverick Tailgate Tie Down Bracket, Clears Tailgate Assist Strut bedliner3a
To summarize - In most cases, my bracket fits most bedliner brands/types with no issues. But in some cases, adjustments or modifications may be required. I am mentioning it so that you are aware.
Because I make these one at a time by hand, my welding may not look as perfect as one that comes out of a factory in China. But it is well-built and solid and it works like it should, and of course, it's made in the USA. In addition, the materials that I use to make the brackets are made in the USA as well - the steel bar stock, chain links, and powdercoating powders.
Ford Maverick Tailgate Tie Down Bracket, Clears Tailgate Assist Strut process1
Ford Maverick Tailgate Tie Down Bracket, Clears Tailgate Assist Strut process2
Ford Maverick Tailgate Tie Down Bracket, Clears Tailgate Assist Strut usa
PayPal is strongly preferred, but if you don't have PayPal and need me to list one for purchase on eBay, I can do that as well. If you have an interest, please send me a private message (don't post to this thread). The amount is limited. Be aware that I'm not a fabricator. I make things because I enjoy making things. And because some accessories just cost too much, and they shouldn't.
My thanks go to @Dean S (his thread here) who came up with this outstanding minimalist design and shared it with us.
Ford Maverick Tailgate Tie Down Bracket, Clears Tailgate Assist Strut proof
mav ir
VA
Lariat Hybrid AWD
I have a few of these available. The steel is thicker than it needs to be, 1/8". Cut, bent, drilled, chamfered, corners radiused, welded, sanded, powdercoated, and shipped to your door for $25 each, shipping is included.
Sorry, I can accept PayPal only at this time. If you have an interest, please send me a private message (don't post to this thread) with how many you'd like. The amount is limited. Be aware that I'm not a fabricator. I make things because I enjoy making things. And because some accessories just cost too much, and they shouldn't. Because I make these one at a time by hand, it may not look as perfect as one that comes out of a factory in China. But it is well-built and solid and it works like it should, and of course, it's made in the USA. My thanks go to @Dean S (his thread here) who came up with this outstanding minimalist idea.
Hi Lane - I would love to get one.... if you send me the Payapl address, I'll send the payment.
Thanks for the solution!
Goosey
Chicago
2016 Mustang
Still have some?
Lane
Lane
Lane
Central Wisconsin
photos.app.goo.gl
Still have some?
Yes, some still available! Please send a private message if you'd like one (if a person isn't familiar - click my profile pic, then "start conversation").
Lane
Lane
Lane
Central Wisconsin
photos.app.goo.gl
Now available - a choice between powder coat finishes. Satin is closer to the finish of the other factory bracket, and wrinkle looks a bit more like a bedliner texture.
Ford Maverick Tailgate Tie Down Bracket, Clears Tailgate Assist Strut Eastwood Wrinkle vs. Prismatic Cat #3.JPG
And if you want to purchase two brackets so they match each other perfectly, I'll include a second bracket for an additional $15 (savings of $5). So a pair would be $40 shipped.
davedogg
NJ
SOLD Jeep Wrangler 2 Door for Mav.
Got mine last week. Have not installed yet but look great! Thanks!!!
Sovande
Alexandria, VA
2026 Maverick XLT
Got mine last week and installed it with zero issues. Definitely looks great and solves the problem!
Lindpoint
Eagle River, Alaska
Ford Maverick 2024 Lariat Hybrid
And if you want to purchase two brackets so they match each other perfectly, I'll include a second bracket for an additional $15 (savings of $10).
I would like a satin black one if you still have more. Thanks
Bret1t
Bret
Southern Illinois
2022 Maverick XLT, Hybrid
Just wanted to give Lane a shoutout.
I ordered two of the wrinkle finish tie downs last Wednesday and they were in my mailbox Friday.
They look great and if I can get 15 minutes of free time, I'll drop them on.
Nice job and great service.
Thanks
Lane
Lane
Lane
Central Wisconsin
photos.app.goo.gl
Thanks
Thanks Bret!
Lane
Lane
Lane
Central Wisconsin
photos.app.goo.gl
Mine arrived today (got here fast) and it was an easy install with a perfect fit. Thank you Lane for sharing these with all of us.
Thanks Steven! Just so it's known that it's a good fit with your drop-in bed liner - what brand of bed liner is that? Thanks.
