Tailgate not flush with rear. Gap normal?
stillyaboy
Justin
Nashville, TN
‘23 Maverick XLT Hybrid
Should this be flush or is this small gap normal?
Ford Maverick Tailgate not flush with rear. Gap normal? imag
Mike215
Bucks County, PA
22 Ford Maverick XLT Hybrid
I believe mine is flush.
Ford Maverick Tailgate not flush with rear. Gap normal? Screenshot 2023-08-11 102530
Stimpy433
Chad
Iowa
2022 Mavrick
Looks like mine….
K5Blazer
Colorado
2023 Maverick XLT
It looks a little off, nothing I would be concerned about.
Body tolerances and alignment aren’t that great on Mavericks.
My hood seam isn’t perfect, and the front fender/bumper seam is a little out of whack.
The tailgate is probably the worst, although you can’t see most of the alignment discrepancies.
After installing a tailgate seal there were a lot of witness marks showing the variations along the bed and gate. I could see where the gate touched flush, and where it mashed the seal.
It wasn’t the seal installation, I lined it up very well with the bed sheet metal.
fossil
ernie
ohio
yes, could be flush. press tailgate forward with hand, it it moves to a flush position the latch is at fault. if not it's probably the post that needs adjusted.
BluegrassNbass
Clif
Washington
2023 XL Hybrid
This is mine, but I dislike this gap instead....
Sitting and if it rains it gets in through here.
Ford Maverick Tailgate not flush with rear. Gap normal? 20230812_070719
Ford Maverick Tailgate not flush with rear. Gap normal? 20230812_070724
Joliet Mike
JolietMike
Morris Illinois
Own 2023 Lariat Eco AWD
I have the same gap only larger maybe. Do you know if tailgate gasket will cover and seal that gap? I have hard roll up cover from Ford.
BluegrassNbass
Clif
Washington
2023 XL Hybrid
Wouldn't know about the hard top cover. I guess you could try and make something work. If I have to haul dry goods in the back I will just throw in a tote. Although I drove through a downpour and everything was dry. So there's that :ROFLMAO:
clos0791
Carlos
Maverick Lariat, Alto Blue AWD
Take it back to the dealer. This looks like an easy fix. Something needs to be adjusted. Its better than having a door misaligned because those can be a pain. The hood can easily be adjusted as well.
I had a hood badly misaligned on my new Jeep wrangler. A friend told me to take it back but I was skeptical because it looked pretty bad. Well, took it back and after about 45min, they said its all done. I went outside and the hood was now perfect; all gaps and alignment was spot on. Even better, no damage or scratches whatsoever to the hood.
Tom03431
Newbury NH
2022 Maverick XL AWD
My tailgate is flush - yours appears to need minor adjustment. Without looking at mine for ref, I must assume this is an easy fix (others have always been adjustable and an easy fix).
stillyaboy
stillyaboy
Justin
Nashville, TN
My OCD says it should be flush.maybe it can be adjusted?
I sure hope so coz it bothers me too. Especially since the other pics in here they're flush. Now i cant unsee how mine is not.
Samcat13
Gerald
The Villages Fla.
Maverick Lariat '24'
HolyCarp
DFW, TX
2023 Cactus Gray XLT Eco AWD FX4 4K
My 23 had i Gap also
Off topic question here:
Why is your license plate on the tailgate? Guessing mobility scooter lift/ramp blocks the stock loaction?
Samcat13
Gerald
The Villages Fla.
No Dealer Plate. I was there to pick it up.
