Tailgate LED light bar for lariat with bliss
DRICH2027
St Louis Missouri
2024 Ford Maverick Lariat AWD
i am wanting to add a led bar to add more break lights so some dumbass doesn't rearend me and they total my truck.
looking on ebay and i see a bunch that are 60 inch and i measures my tailgate and nor even close. Not sure how they advertise it for a maverick
what size has people used ? types ? brands? and is there away to NOT attach to the trailer as this turns off bliss
thanks so much for your help
dave
BlueSpec1
Gene
Hot Runr Guy
West Chicago, IL
Dave,
I've probably read every thread on this subject, and IMO, the only way to foolproof an install is with using a powered trailer light harness, like the Curt # 56477. However, even that isn't a 100% solution, since the Curt harness will not provide a reverse light signal, if you select a light bar that has that feature. Adding a reverse light wire would be easy enough, if you are comfortable with that kind of work.
https://www.curtmfg.com/part/56477
HRG
dmopro
Richardson, TX
This is what my local dealership is selling:
https://pulseprotects.com/
I have not tried it and don't have an opinion, just noticed the ad on the salesman's desk.
I went the cheap route and got the same effect (3rd Brake Light pulses 4 times) simply by putting in this LED bulb.
Amazon.com: FANTELI 921 LED Bulb 6000K White, Strobe Flashing LED Reverse Lights, High Power 921 Bulb 21-SMD LEDs Error Free T15 912 922 906 W16W Backup Light (Upgraded, Pack of 2) : Automotive
Ichaya
Dawn
2024 Ford Maverick Lariet
What is blis?
Bobby Chapman
Bobby
Orlando fla.
2023 maverick
This plugs right into the trailer plug and does not make the guidelines in the rearview cam disappear. I had to mount below my bumper on a 1 1/2" alum.angle bar . For it will not fit properly under tailgate
Used all factory screw holes under bumper to attach alum. Angle
Visit the Store, ONLINE LED STORE
ONLINE LED STORE
Visit the Store
4.3
4.3 out of 5 stars
(824)
True Mods 49" LED Tailgate Light Bar + Signal Relay Box [Ford F-150 F-250 F-350 Super-Duty up to 2018] [Sequential Turn Signal] [Tail & Reverse Light] for Ford Pick-Up Trucks with Tow Package & BLIS
Amazon copy above to get to.
Ford Maverick Tailgate LED light bar for lariat with bliss 17362648294146592696687065634098
Hot Runr Guy
West Chicago, IL
Didn't realize your XL had the Co-Pilot360 w/BLIS option. Thanks for the info.
HRG
CTYankee
Central MA
2022 Maverick XLT
umpkey
Bunnell, FL
Litghtbar installs seem hit and miss:
Putco lightbar kit seemed to have issues both with Mavericks and Rangers.
https://www.mavericktruckclub.com/forum/threads/problems-with-tail-lights.25349/post-704390
OPT7 sells harness for Maverick, it says w/o BLIS, also hit & miss:
https://www.mavericktruckclub.com/f...-for-maverick-now-available.57621/post-995427
I added the OPT7 harness to my 24 Lariat last month, even though it says without BLIS, my BLIS and CoPilot 360 options work as intended. It was very easy plug and play, the hardest part was removing the cover part on the bottom of the rear passenger side to run that sides harness up to the tail lights and that wasn't really hard just a PIA.
I have this current lightbar installed and works great.
Nilight 48”/49” LED Tailgate Light Strip 90 LED Red/White for Running Light Brake / Turn Signal / Reverse Light,2 Years Warranty
https://www.amazon.com/dp/B0841K5FJB?ref=ppx_yo2ov_dt_b_fed_asin_title&th=1
Hope this helps.
