Tailgate Cable Alternative
Jeff D.
Jeff D.
Jeff
Duluth, MN.
I like to show my adult daughter the scar where I cut a pumpkin-seed-sized piece of my fingertip off with an X-acto trying to frame art for her room, the weekend before she was born. The blood made a mess, but I enjoy having the story and the odd remembrance of that time.
My grandfather had a finger that was pretty mangled on the end. He always told us grandkids it was from a bear biting him. 😏
I'm positive it wasn't, although I never knew what it was really from. :unsure:
riparian
Virginia
2024 Maverick XLT hybrid
I owned several pickups built in the 70's and 80's that had the bar-type tailgate supports. They had enough play at the swivels that they would occasionally bind, requiring a quick push at the mid point to get the tailgate to close-kind of a PITA. I've had several later pickups with the cable supports and find them more trouble free. They've stood up to any loads imposed on them, which have been frequent and often substantial. I guess if I ever broke one I'd just replace it and move on .
Jim Walker
23 XLT Tremor
Thanks, John. I do have one of those and like it. (y)
The linkages I was referring to would replace the cables for limiting the tailgates travel. I've noticed the tailgate seems to go past "level" when a load is on it, I'm nervous about cables breaking when the tailgate has a load on it, and Mavericks have had issues with the cables not being the same length. One cable takes a disproportiante amount of the weight when it's like this, and can cause a twisting stress is the tailgate when it happens.
The linkage (arms) I am thinking of were used for many years and seemed like a good idea. There may be a good reason cables are better, but I don't know what that would be.
In my example below, if the cable were to break my snowmobile would certainly be put in a dangerous position for me and other motorists. That's my fear. I'd be more comfortable with the old style arms in that instance.
Your right about put other people in danger, unsecured load, your losts, asking a lot out of your tail gate
NewcMaverick
Kyle
Indiana
Cruze
I remember growing up using my Dad's '88 Chevy and they binded often. I remember "karate chopping" them down almost every time you had to close the tailgate. I bet my Dad would still be driving that truck if he didn't total it lol
As I mentioned in my thread, having to do the same thing. Corrosion and not being a great design added to us having to coax them to bend, in order to close the tailgate.
When hauling the snowmobil you'd be better off using a trailer. At least that would be the safest route.
For a snowmobile, I agree a trailer would be the way to go.
I mean if you're already storing a snowmobile keep it on a trailer.
Sure seems better than beating the crap out of your tailgate.
Lone Ridr
Ron
Degonia Springs, In
2024 Ford Maverick Lariat
I remember on older trucks, atleast '70's and prior Chevys, they had metal arms that were used instead of cables. These seemed to work good. They could be disconnected and the tailgate removed easily, they were easily inspected for corrosion and wear, and they certainly could carry loads.
Why did they go way from that design? Was it cost alone? They didn't take up alot of room, as they were fairly narrow, and I believe they might even be able to fit in the same area the Mavericks cables do.
I had an '95 Chevy that broke a cable. It was corroded and I couldn't see the corrosion as it was covered with rubber. At that time I thought it was a poor design.
Perhaps I'm missing something? I'd be interested in replacing my cables, if an aftermarket design similiar to the earlier ones were offered for the Maverick. I'd certainly be less worried when carrying a load on the tailgate, which happens on the Maverick alot more due to the short bed.
I worked in a Chevrolet parts department in the 60S before I was drafted and went to Vietnam. I had the part numbers memorized for those hinges - sold a bunch of them. They would break at the bottom pin, both sides, dumping the load and anybody standing on the gate to the ground. Many customers angrily told me about serious injuries to the hips, knees, ankles, head, etc. Some of the customers said they were just standing on the gate when the hinges let go. I, for one, wouldn't have a set on my truck if someone offered them.
jonshep
SW Oklahoma
IMO cable strength on the Maverick is moot. I will bet the cable is far and away stronger than the attachment points and/or the tailgate.
Shock96
Olympia, WA
2025 Maverick Lariat Hybrid AWD
The thing with winch cables is not only are you pulling the truck/Jeep whatever but getting it unstuck.
Ford Maverick Tailgate Cable Alternative 1741055815330-nk
Blue316
Reggie
NW Washington
The cable is only as strong as the ends swaged onto it. It doesn’t matter how many tons the cable is rated for, it is most likely weaker at the swaying.
I used to haul all kinds of small cars, etc, in the back of an early 70s Chevrolet 3/4 ton truck, using the tailgate as a bed extension. Went to the scrap yard many times with cars stacked two high(without roofs).
As long as the hinged stops are maintained with oil/grease there is rarely a problem with them. I don’t remember ever having to do anything other than push them in the correct direction as they would fold either way.
