Tailgate assist
BrothrFree
Brad
Terre Haute, IN
Toyota Venza
Installed the tailgate assist on mine - Love it so much I'm going to order the hood assist.
K Ayd
Kevin
Mn
2005 Grand caravan
Has anyone installed the lift cylinders on the tailgate and or hood of your Maverick? They are not very exspensive I am thinking of putting one on my tailgate for sure. My wife drives mine more than I do and it would definitely make lowering the tailgate easier for her.
If she keeps driving my truck I might need to buy another!
I have one and I love it
DonPassmore
Donald
Hummelstown, PA 17036
Maverick Lariat 2022
Yes, it was very easy to install. Just follow the instructions and make sure you have the proper tools. You may want to use silicon jell or vaseline on the bolts to make it easier to screw them tight. I had an issue with the bottom bolt.
DaveR
FL
2023 Maverick Lariat
Yes, added the tailgate best thing ever. Bought it week before my truck came, on Amazon 2023 Lariat.
Ponchsox
Subaru Forester
Installed the tailgate assist today. Took about 20 minutes. Super easy. Best $27 mod you can make. Buy the Dee Zee from Amazon. It’s the same thing that Ford Sells and it’s $23 cheaper.
Dignam
Madison, WI
'25 Maverick Lariat
Finally got around to installing mine today. Was pretty easy, the trickiest part, as others have noticed, is the bottom plate and nut that goes in the tailgate. I found using a plastic trim tool between the plate and metal to keep pressure on the nut and plate made tightening it relatively easy:
Ford Maverick Tailgate assist PXL_20230527_194302936
rivermaverick
Fort Mohave AZ
I'm thinking of installing the tailgate assist kit, I'm surprised how heavy the tailgate is! A couple of questions though:
I know that gas struts can get stiff when it's hot and it does get hot here in the Mohave Valley - 115 plus, will that make it hard to close the tailgate on a hot day?
Also it looks like you have to remove the 2 black bracket thingy's that I assume are there to guide the tailgate support cables. I figured the Ford in their infinite wisdom put them there for a reason, has anyone had a problem with the cables getting trapped?
lajlmt
Lance
Rio Rancho
‘23 Maverick XLT LUX
It’s on my amazon prime day list!
wito53
WARREN
NH
05 outback, 2015 forester, ordered 2024 maverick
Do you need Torx Plus drivers to install these? Thought I read that somewhere but can't find it.
Zed79
Zed
UP
22 XL AWD
Only have to remove the one tiedown bottle opener on the drivers side. they are just tiedown points nothing more.
Gray Goose
RG
Wissota
The cables get jammed by the bottle openers all the time. I'm planning to remove them just for that reason. If you've done the assist kit, do the cables catch on that?
Lane
Lane
Central Wisconsin
photos.app.goo.gl
I've had no problems with the assist strut contacting the cable.
If you'd like to re-add a tie-down bracket that clears the assist strut, I've made a few and have them for sale here.
Ford Maverick Tailgate assist image1-
Also doesn't interfere with the motion of the cable or jam it up, if that's a problem you're having with the factory bracket.
MavGirl!
Terrie
East TN
Maverick Lariat EB
I have one. I ordered the KlutchTech model for my 2024 Lariat, from Amazon. It had a 5% coupon with it, so it was $23 and some minor change. It was less than a 20 minute install. I love it, and it definitely makes opening the tailgate very simple and smooth.
The KlutchTech model comes with a Maverick sticker, to place along the length of it. Kind of neat looking.
I added a folding tie-down rated a 900lbs. To replace the oem tie-down/bottle opener, that I had to remove when I installed the strut.
Ford Maverick Tailgate assist 20240529_154452
srfdude44
california
kia optima
I have installed both the tailgate and hood dampeners, very easy and fairly quick installs. Hardet part of both was removing the clip for the windshield washer fluid. Both work great
I wonder if the washer is in a different location between hybrid and Ecoboost. I didn't have any trouble with anything when I installed mine.
