Tailgate assist issues....
f1jim
Pacifica, CA
2025 Maverick Lariat
The ball on the upper mount of the tailgate assist assembly snapped off(3 months use) and for the life of me I can't figure out how to release the loose ballmount from the head of the top of the cylinder. It's got a plastic thingy holding it in place and I can't figure out how to release it. Anyone out there that can help this dummy?
oysterville
Oregon
2024 Maverick Lariat
Is that an after market part that you installed or OEM?
Pictures and Brand of the Tailgate Assist will help but the ball usually just snaps in
Yep.
You're right it, just snaps on and off.
Here are some pictures of the lower ball attachment point. I hope this is what the op is referring to.
I use a HF plastic pry tool.
Ford Maverick Tailgate assist issues.... IMG_20250425_103332
Mikeske
Michael
Washington
For a $20 to $40 part from Amazon. I would say just take the brackets off and replace the entire assembly with a new one. The replacement strut which will be cheaper to get it with all new parts
f1jim
Pacifica, CA
Those pics are exactly what I am looking at. The ball isn't coming out with moderate force. Will use as much force as these 69 year old arms can muster.
Thanks
f1jim
km@c
Ken
Leesburg, FL
2025 Maverick XLT hybrid
If you're asking how to remove the strut from the ball, take a small straight blade screw driver and pry open the spring. There should be a small slot on the top of the spring. Pry it open to release the spring and it will come loos
f1jim
Pacifica, CA
More force did the trick. Now the broken ball is separated from the top of the cylinder. Not sure about a spring.
f1jim
Ozarkbeard
f1jim
It is a C-shaped clip. It is removed by prying it with a small flathead screwdriver.
Fcnrwy
Jerry
Wisconsin
Maverick XL Area 51
f1jim
Ford Maverick Tailgate assist issues.... Tailgate assist
What brand is your example??
Jerry
f1jim
Pacifica, CA
It was Klutchtech. Never did figure out the spring clip thing. I just yanked till the ball separated from the socket. So you use a small flatblade in that gap in the mount as shown by that last pic?
f1jim
DScruggs
Don
Silver Spring MD
2009 F150, 2020 Pacifica Plug-In Hybrid, 2025 Maverick Lariat Hybrid
f1jim
No. The flat blade screwdriver goes on the back side of the clip. That is out of view in the picture. I will try to take a picture.
Martymav
Martial
Winnipeg, MB, Canada
2022 XLT Maverick
The blue arrow points at a spring clip, this clip must be removed , I usually use and awl t
Ford Maverick Tailgate assist issues.... 0l9qbe3n
hen it should just slide off.
On my struts, I have recessed areas, identical on the top and bottom. Where you can either use a awl or screwdriver to pop the clip and slide the socket off of the ball.
Ford Maverick Tailgate assist issues.... 20250426_092956
Ford Maverick Tailgate assist issues.... 20250426_100928
Ford Maverick Tailgate assist issues.... 20250426_092646
Here is the bottom view. ☝
