Swollen Nuts ( Lug Nuts that is )
Hot Runr Guy
West Chicago, IL
The correct size is a 19mm with the first thread being by hand to prevent damaging the starter thread and the final 20lbs of torque being done with a torque wrench by hand
With all due respect, a 19mm socket does NOT fit the 14mm thread lugnuts that my 2023 FX4 Maverick has. Maybe you are used to a Ford vehicle with 12mm studs?
HRG
JennyJoannSuebeeMcNash
Jenny
East Coast Florida
2016 Ford F150 XLT
E.S.S. couldn't resist... a movie from my teens.. Johnny Dangerously..
OMG. I remember seeing this move as a teen. I even had the prison scrub shirt that said Free Johnny Dangerously. Thanks for a blast from the past!
Hot Runr Guy
West Chicago, IL
In other words, the Maverick uses a 21mm or 13/16" socket for the lug nuts.
I find that my 13/16" (.8125") socket fits better (tighter) than my 21mm (.8267").
HRG
TheWizziard
Texas-RGV
When I first heard about two piece lug nuts I did a little research. A number of studies suggest that they are not "swollen" by rust but that the cover is damaged or twisted on the base metal by installing and removing. HTe rust appears to be secondary.
I had two piece lug nuts on my 2011 Ranger for 12 years without an issue.
That being said, I live in an area with little rain fall. I didn't rotate my tires. I ran one set of tires for 10 years. Only had two flat tires in 12 years. And I don't change to snow tires.
Even though I had no problem, I can understand the potential problem with these nuts. I assume the OEM's justify them as a cost avoidance. There are a number of threads here and on other forums with replacement nut options.
I haven't decided if I am going to replace mine yet. I still have a number of other mods to finish first. (the mud flaps just arrived.)
Normal, IL
2023 Lariat Hybrid A51
:p
Ok friends some questions for the car geniuses on here.
Are all the stock Maverick lug nuts two piece and if so are they likely to cause a problem with swelling down the road, even if I live in a drier desert climate?
I am thinking of going to black since I have the BAP on a Lariat. Especially if the consensus is to replace stock.
Any recommendations from those in the know or who have already switched them out?
Thanks in advance for your input!
I switched to solid black for less than $70 installed by Discount Tire. This after my wife’s Explorer had a flat in the Northwoods and the lug wrench wouldn’t fit on 2 of the nuts.
Mav_RICK
Mav_RICK
Rick
Arizona
Ford F150
Purchased from Discount tire as well?
1929
Lake Michigan
Ford Maverick XLT Hybrid
Is 21 mm the correct socket for lug nuts on 2023 Maverick?
fossil
ernie
ohio
Guess I'm lucky. Many years driving Fords in the rust belt and not one lug nut failure. 90% of the time used a 1/2" impact wrench on medium power on/off. Torque wrench finish.
My 95 SHO is still on orig OEM nuts, can't say for sure on the Cobra but they are Ford Nuts.
Ford Maverick Swollen Nuts ( Lug Nuts that is ) 200w
Waterick
Richard
Laurens county SC
I have lived in South Carolina now many years and never had a swelling problem with any of my three Fords. One of my old Rangers did have some of the lug nut caps detach after several years. This vehicle did see several snow storms in the NE and Northern NY from many holiday trips to see family. No rusting of the lug nuts just cap separation. Replaced them with one piece as needed (maybe four). This vehicle had over 200k when I sold it. I have always rotated the tires myself, but the tire guys did get at it when mounting and balancing. I'm sure this is what deformed the caps.
