- First Name
- Bob
- Nov 5, 2025
- N Kingstown, RI
- 2025 Ford Maverick XLT
- Engine
- 2.5L Hybrid
My 2025 Maverick XLT is my first venture into the electric/hybrid vehicle space. However, I have been dealing with battery technology for over forty years in the marine environment and have a few thoughts on the subject
Most of the posts I have reviewed discuss AGM vs lead-acid battery replacement for the deep sleep problem and seem to offer mixed results. While AGM are more rugged in harsh environments, offer low maintenance and better recovery from deep discharge, in operation they are not that much different from lead-acid. More important is what kind of battery they are. Common to both are three types:
Also common to each is how the lifespan can be shortened:
Over charging – typically caused by not using a three-stage charger or a bad voltage regulator/charger
Constant drawing battery below 50% capacity, thereby reducing the overall life-cycles available.
If you suspect the battery low State of Charged (SoC) or damage to the battery is caused by parasitic power drain, for starters it would make sense to put a combination type, either AGM or lead-acid, battery when replacing.
This leads to the question of what the dc-to-dc system is doing. Does it support a three-stage charger for the 12-volt system? If not and just applies a steady voltage to the battery, question answered, the battery will not last very long. One clue would be when changing between a lead-acid and AGM battery, does it require any software adjustments to accommodate the different charging voltages? If not, the higher charge voltages that lead-acid batteries take will certainly damage the AGM battery. Another possible reason why there seems to be a mixed bag of results. It might be the charging, not the parasitic power drains that are the issue. Other questions that I have are: Has anyone actually been able to determine what the 12-volt battery voltage is when the vehicle goes into deep sleep mode? If so, can it be easily replicated?
I have not yet experienced the issue with my two-month-old Maverick, so it is still an academic issue to me.
- Deep cycle – made for constant, lower drain, long term loads. Not good for short, high amperage draws, like starting an engine. Physically, the plates are heavier duty.
- Start - Good for short high amperage loads, not good for long term parasitic draws.
- Combination – designed and manufactured to meet both needs
