Storing My Maverick - any tips besides battery tender?
OLEO
Leo
Clio Mi
2023 Ford Maverick XLT
I am going to park my 23 Maverick Hybrid for three months at my Michigan home. I will hook up a battery tender on the 12volt battery connections under the hood. Is there anything else I need to do to store it correctly. Thanks
Waterick
Laurens county SC
I would store it with non-ethanol fuel in the tank, if it's readily available in your area. Make sure you stabilize the fuel otherwise.
wax87
Stuart
Dallas South
2004 Avalon
change the oil
inline_five
2023 Hybrid XLT
Keep it off the ground. If you can't do that, inflate tires to 45-50 psi. Also use a ton of rodent spray and hope they don't set up shop.
Paulyz
Paul
Forestville, WI
When I store my Mustang over the winter here in Wisconsin, I use a battery tender, hood open with light on in garage, mice like dark, put steel wool in exhaust pipe, in air intake, and make sure nothing edible in car. I also put mothballs on engine and in car & trunk. I keep tires on pieces of plywood, plus stable in gas tank. Never had a mouse problem and starts right up in Spring.
Snowbird
Vermont/North Carolina
Honda CRV 2018
I believe I read on this forum that the owners manual has some information on what to do if you are not going to be driving your vehicle for extended periods.
Disconnecting the negative battery connection seems to ring a bell.
Fmp0926
McLeod
2022 Ford Maverick XL
I tried using peppermint oil in the engine compartment but that obviously hasn't deterred them!
Ford Maverick Storing My Maverick - any tips besides battery tender? 20241226_164442
888Mustang
Albany NY
24 Maverick 95 Mustang GT Vert 20 Acura TLX
Hot sauce -dish soap-water in equal parts
Jalopy Technology
Rick
Central Wisconsin
'25 Maverick, '04 LeSabre, '99 Grand Cherokee, '88 F350 crew cab, '65 Dodge Coro
Park it and forget it
my experience with battery tenders is they tend to overcharge the battery. My friend had a battery cook while on a tender and it pissed acid all over his pristine restored Mustang engine compartment.
FreedomPenguin
Dayton
I have a 4 bank battery tender jr I’ve had no joke 10 years, I even have a solar power battery tender to 12v converter in shed on mower battery
Batteries ran way beyond their intended life, I just replace 6-7 years due to age not health but I attribute the tenders to being awesome
Jalopy Technology
Rick
Central Wisconsin
If you’re worried about a discharged battery have FordPass start your car every couple weeks and let it charge for 1/2 hour
FreedomPenguin
Dayton
if its stored inside a garage or something, that could kill someone or pet. lol. imagine not knowing that someone moved it into garage or something. and him remote starting it. that would be tragic. (but I dont know if 30 minutes is enough for exhaust killing)
Jalopy Technology
Rick
Central Wisconsin
People park their cars in the garage?
Huh…
:crazy:
