Hood alignment, any tips?
MavisTheMaverick
Dylan
2024 Ford Maverick XL Ecoboost FWD
I'd like to get the rear of the hood more in line height wise with the fender. The front is easy enough to adjust, but at the rear it looks like I'd have to remove the fender complete just to adjust the hood up or down. Just want to make sure im not missing something more simple. Thanks for any help!
Ford Maverick Hood alignment, any tips? 20241226_133457
Uncle Ed
Georgia
1968 Camaro, 2017 Toyota Highlander, 2024 Maverick hybrid
You might be able to get to the hinge thru the gap when the door is open. Hinges used to be adjusted from there to raise or lower height. If that doesn't work a shim at the hood to hinge attachment point will raise the hood . If the truck is fairly new dealer might adjust it for you as a courtesy.
MavisTheMaverick
MavisTheMaverick
Dylan
I didn't think about going the open door route, I'll definitely try that. It's brand new though so i might go by the dealer first. The shims are another great idea. Thank you!
