17 to 18 in size change
Area51BS
Ron
I assume Forscan allows for changing tire size from xl tire size to a Lariat rim/tire size.
ShadowChas
Chuck
2022 Ford Maverick XLT FX4
Depending on what size tire, you may not need to do anything. The outside diameter can be the same if you just get lariat size over the xl/xlt size since it goes from 65 series to 60 series (online tire shopping can show what plus size can be done to stay the same - like a sponsor here discount tire or tirerack).
Area51BS
Ron
Ok. I know it’s done with Forscan on the Bronco.
EONR24
United States
2024 Ford Maverick XL
Check out my Ultimate Forscan Spreadsheet ! Look for "Adjust OEM Tire Size". you can change to one of the 4 factory options easily. There is a way to set up custom tire diameter too but it is a bit more experimental!
basepatrol5
Cincinnati, OH
'24 Lariat FX4; '04 Mustang GT
Just saw your Google Sheet... great sheet, but I don't see anything about tire size change (???)
EONR24
United States
I removed it as it causes DTCs that cannot be removed easily! I didn't want anyone to get unremovable DTC codes. I can add it back as it does work but it does cause DTCs. It is the same procedure on the Bronco Forscan Spreadsheets.
