Spray in Liner and Bed Covers
ARob301
Adam
Maryland
Order: 25 XLT Eruption Green
I just picked up my 25 XLT Eruption Green, really enjoying it so far. I need to get a liner and cover for the bed. What have people been paying for a spray in liner and what tri fold covers have you got? Thanks
Eggflipper
Gene
Massachusetts
2024 XLT TERRAIN
I got the factory Tri fold. I’ll get a few drops inside, but I’m not expecting water tight.
BlueOval1954
These are a bit pricy but I love how it works. Easy to roll up & down and does not block very much of the rear window. If you mention MTC, they should give you a discount.
RealTruck Bak Revolver X4s Hard Roll Up Tonneau Cover
$1,399.99
4.3(1541)
Starting at $117/mo or 0% APR with Affirm. Check your purchasing power
Guaranteed Fit
2023 Ford Maverick, 4'4" Bed
Change vehicle
RapidShip Ready
Free Shipping - Ships today, order within 05h22m57s
Add Professional Installation
Part #:80324
Spray in bedliner from the factory.
XL Hybrid Cactus Gray
United States
2022 Ford Maverick Hybrid XL
Same recommendation on the Bak X4s rolling hard cover; I chose that and love it.
After discount from Real Truck, I paid around $990.
Bedliner, I paid $650 for Line-X spray in service.
Was $550 for normal and extra $100 for "premium", which was basically a layer of clear coat added for UV protection and gloss look (but tonneau cover prevents UV/color fade anyway). Overkill for premium spray, but I like it. I got the spray done before I added cover later.
Have used Line-X Spray in on all my trucks.
Snox801
Levi
Spring Lake Michigan
I did the raptor liner myself. Took basically one nice day. With all the supplies and everything was less than $200. And about half day of actual labor.
pigsareus
Farmington Hills, Michigan
Maverick XL Hybrid
i have the factory tri fold cover - it's fine, sturdy, well made, Simple install with a couple clamps on the inward side, typical spring tension (pull down) clamps on the tailgate side, had it to years, vinyl is still intact, no cracks or anything. But...you might want to consider a roll up cover in that a trifold when fully 'open' still = you have 1/3rd of the bed still covered. Not a big deal but if you need full access you have to remove the front clamps, remove it and then store it somewhere. As to the liner I just have the factory rubber mat - it's really good, very heavy , fit very well and no concerns about it blowing away. Figured that it/when the bed gets scratched up then I can decide to get some spray in liner - spray in liner makes any scratches 'disappear'
Adam,
What type of budget are you working with for the Tri-Fold Bed Cover?
How often will you be hauling large items where you need to to use 98% of your bed above the cover? Necessitating the removal of cheaper folding bed covers. A true trifold that blocks the rear window when folded up. WIll offer the most usable space and offer some protection from a large item hitting your rear window.
. Spray-in Bed Liner can be anywhere from about $200 if you do it yourself.
To over $800, especially if you want color matched eruption green bed liner. A regular black rhino or Line-X between $500 and $700 dollars.
ARob301
Adam
Maryland
Was there a promo code for Real Truck or how did you get the discount?
United States
Toddman45
St. Louis, MO
Would you mind posting some pictures of it.
Ravinus
Kevin
Virginia
2025 Maverick
I got the BAKFLIP MX4 tri-fold. I’m pleased with it.
Wilklersticks
Bryan
WI
25 Lariat Hybrid 🚀⬜
I went with the Rough Country Hard Tri-fold. https://www.roughcountry.com/product/ford-flip-up-bed-cover-49254500
I got mine through Bezos, but I've heard direct from them ships free so I should have thrown the money their way, not his. The "2024" fits perfectly.
I debated the BAKFLIP like the others, but decided I didn't need the ability to have the cab light shine when fully "rolled up".
Paulyz
Paul
Forestville, WI
When it first arrived I had Bullet Liner do the spray in bed liner $500, and undercoating - rustproofing for $500.
I also ordered the Truxedo Sentry hard roll up tonneau cover for around $1,000. Also Weathertech Splash Guards for about $100.
I am happy with all of these. Been 2 years since my Maverick arrived.
