There is always some misconceptions about spring vs. spacer lifts.
Figured I would throw this out there to get some information in the forum.
Spacer Lifts-
Pros - cheap, first to market, doesn't change static position of shock
Cons - You just added the spacer thickness of droop, and are now added more angle into the CV's then was designed for. This can be said for bushings, sway bar end links, tie rods, etc. (true for struts, multilink rear may or may not have these problems depending on what is actually done)
Spring Lifts-
Pros - Does not change suspension travel/droop. Rate can be increased/decreased for load/ ride comfort.
Cons - Increases static ride height and position of shock, limits droop. Too much rate increase and overwhelm OE valving.
Do people combine these two? Yes, should they? Absolutely not, but that hasn't stopped crosstrek owners lol.
At the end of the day lifting an SUV, or in our case "truck" that is based off of a car platform will have limitations. 1.5"-2" of lift is about all you will get out of it with longevity and ride quality in mind.
Spacer Lifts-
Spring Lifts-
