Simple DIY Folding Maverick Bed Divider – $30 Build
mikeymaverick
Wisconsin
2023 Maverick Lariat
I want to share a simple, easy-to-make folding bed divider for the Ford Maverick. Here's what makes it different from a standard single-board divider:
  1. It folds in half, so it’s easy to store flat in the bed when not in use.
  2. The latch makes it quicker to install and remove compared to sliding a full board out of the slots.
  3. I added a small folding arm to keep my gas can from sliding around during transport.
I used 2x6 treated lumber, galvanized non-removable pin hinges, and a galvanized latch. I beveled the boards behind the hinges so they sit flat when folded, and I also beveled the bottom ends of the divider to match the angle of the slots in the bed. I kept the boards raised slightly off the truck bed to help prevent water damage.
Here is the divider installed with a gas can.
Ford Maverick Simple DIY Folding Maverick Bed Divider – $30 Build IMG_2504
Here is the divider installed without the gas can.
Ford Maverick Simple DIY Folding Maverick Bed Divider – $30 Build IMG_2498
Here is the smaller arm folded up.
Ford Maverick Simple DIY Folding Maverick Bed Divider – $30 Build IMG_2499
Here is the divider partially folded up.
Ford Maverick Simple DIY Folding Maverick Bed Divider – $30 Build IMG_2500
Here is the divider fully folded up.
Ford Maverick Simple DIY Folding Maverick Bed Divider – $30 Build IMG_2502
I hope this can help someone!
Ford Maverick Simple DIY Folding Maverick Bed Divider – $30 Build IMG_2503
Pigeonman
Petoskey, MI
2025 Lariat, hybrid, 2015 F150 with topper, 2023 Escape, hybrid
Nice to see a creative mind in action.
AMTRV
Norris
TX
24 6.7 Tremor, 22 Bronco Badlands, 25 EB AWD 4k
Very nice, simple, useable design.
scharris99
Daytona Beach
2025 Maverick XLT
I was going to use a 2x10, but PT was WAY too heavy for my wife or anyone else to deal with, backpedaled to to KD, still too heavy, ended up with 1x KD pine doubled at the ends to fit the slots, notched the outside bottom to fit into the drop-in bottom pan & rounded off the top for removal clearance. Might add some hooks for grocery bags or a cargo net.
Dannoo
mn
2025 maverick
Maybe some stain and be awesome!
Gray Goose
RG
Wissota
I like the design, but why treated?
With a bed cover, treated seems like overkill.
Construction grade lumber will last for years if allowed to dry out after getting wet. With a coat of paint, decades.
scharris99
Daytona Beach
2025 Maverick XLT
Exactly! PT is much heavier & can't be painted. The only use would be to prevent rot/bugs if you're hauling firewood or mulch a lot.
mikeymaverick
mikeymaverick
Wisconsin
I went with treated because the cover still leaks enough that I didn't want to worry about it. It was also only $3 more.
Sonnytnguyen
Sonny
Monterey
2022 Maverick XLT
Very practical and easy to. Ake. Thanks for sharing this idea and pictures.
Buggy Man
Summerfield Fl
2025 Maverick Lobo, Meyers Manx clone dune buggy
Nice job. I like the center hinge making it easier to install/take out. I'll have to make one of these. Thanks for posting.
