Shock tower brace improves stability on handling?
Dennis
Kansas City Missouri
2025 Ford Maverick Lariat
I have a 2025 ford maverick lariat hybrid.Do you think a shock tower brace improves stability on handling at all? Or is it a waste of money? Let me know what you think. Thank you!
Chops
Lobo
Several of us on the forum who installed one all claim more confidence while taking corners.
Would that confidence be shaken if someone secretly removed it?
Nope. Or at least not until we opened our hoods and noticed it gone.
What is the price of having more confidence? About $170. Of course they look cool. That said, I think we all drive the EB and the confidence booster may not fit on a Hybrid.
edit…grammar as usual
r0tax
CO
2025 Lobo 402A VB
Consensus is, if your trying to fix the Understeer on this car, look into a stiffer Rear sway bar first. (not sure what options there are for a Hybrid, i know the suspension is quite different in some regards vs the EB.)
I think Unless you are deep into suspension mods and regularly at the limit, there are better places to throw money.
But if you need an easy fashion statement, go for it.
(I don't have one, nor have experience with one, basing my info off others who do.)
Chops
Lobo
There are only a few of us that have actual experience of a Maverick before & after a strut brace install. All report having more confidence while taking corners.
Until someone installs a strut brace on their Maverick and reports that the brace did not improve their cornering confidence - I’ll remain confident in my strut brace.
Even then, I’ll probably blame their lack of cornering confidence on them being a weenie.
That said, my tongue is in my cheek - and totally agree with you that a rear sway bar will decrease understeer.
But not as pretty as a strut brace. That is why so many SCCA drivers have strut braces installed on their shorter shock towered vehicles. Look cool, drive faster!
Blue_Max
Orlando, FL
I'm interested in a strut brace down the road maybe, but not before the OEM tires wear out and I replace them with something better.
asylus
George
TEXAS
'24 Ford Maverick Lariat Tremor
I considered one form steeda or massive for a while then realized it wouldnt improve the turning radius and might actually take away from off roading.
James K
NY
2022 Maverick,1960 Bugeye, 1973 GT6, 2016 R1200GS, 2024 KLX300
100% agree. Normal driving is not going to be improved. The more aggressive you are, the greater return.
Tbone289
There's nothing that a strut brace does or claims to do that will negatively affect off-roading. With that said, I don't believe that a strut brace provides much of a benefit on a vehicle that has the strut towers attached as close to the firewall structure as the Maverick.
A stiffer rear swaybar will negatively affect off-roading however, as the stiffer it is the more it decreases available rear suspension articulation.
asylus
George
TEXAS
How Strut Tower Braces Affect Performance
  • On-Road Performance:
    By connecting the top of the strut towers, a strut brace reduces chassis flex and distortion, especially during cornering. This results in a stiffer, more stable feel, crisper steering, and improved handling by keeping the wheels more firmly planted on the ground.
  • Off-Road Performance:
    The increased chassis rigidity provided by a strut tower brace is often a detriment off-road.
  • Reduced Compliance: The stiffer chassis makes the suspension work less independently, which is necessary for absorbing the impacts and twists encountered on uneven off-road terrain.
  • Hindered Suspension Travel: A more rigid chassis can limit the suspension's ability to articulate and maintain tire contact with the ground on rough surfaces.
  • Chassis Torsional Load: In challenging off-road situations where one or more wheels may lose contact with the ground, the chassis can twist, potentially misaligning the doors and body panels. A strut tower brace, by design, resists this twisting motion. While this helps maintain unibody integrity, it also means the forces are transferred through the suspension, potentially making the ride harsher and compromising tire contact.
In Summary
  • Not for Off-Roaders:
    Strut tower braces are primarily for on-road tuning and performance enhancement.
  • Increased Rigidity is a Drawback:
    The stiffening effect that improves on-road handling makes the vehicle less forgiving and adaptable to off-road obstacles.
  • Prioritize Suspension Design:
    Off-road vehicles rely on a suspension that can move independently and absorb terrain irregularities, a function that strut braces counter.
Tbone289
There are MANY false statements in that text. I'm assuming that is an AI response, and a shockingly bad one.
Suspensions will work better and more independently from the chassis the stiffer the chassis is. Strut braces increase chassis rigidity, allowing the suspension to do more of the work, and absolutely do not affect suspension performance.
asylus
George
TEXAS
There are MANY false statements in that text. I'm assuming that is an AI response...
Suspension will work better and more independently from the chassis the stiffer the chassis is.
Def Ai response but are you talking about body on frame?
Tbone289
Macpherson struts, strut towers and braces on a body on frame chassis? Um...no.
My advice would be to not rely on AI and listen to people who have worked with suspensions on unit body chassis.
Ford Maverick Shock tower brace improves stability on handling? 1755874501900-td
asylus
George
TEXAS
Thanks for the response. Can you point out the false statements please?
Tbone289
False statements crossed out. Strut braces increase chassis rigidity and allow the suspension to do more of the work on its own, which is contradictory to the suggestion that they limit the suspension's ability to articulate and work independently.
In Summary
Speed2000
Woodstock Ga
Acura TSX Sportwagon
If you drive so fast you think you need a strut bar to keep you from crashing, you should have your drivers license revoked.
