Rust on / around bed tie downs
Hockeyfish11
Ed
2024 Maverick
I have notice that the junction where my tie towns meet the bed rust has formed. A good portion of the rust is rust particles. I appears to me that then the tie downs were drilled for installation the metal shaving were not removed. If the tie downs are a factory install I doubt that is the case. I am glad I caught it before any serious damage was done. Thoughts? Observations?
Ford Maverick Rust on / around bed tie downs IMG_2632
Ford Maverick Rust on / around bed tie downs IMG_2631
Cancunbadlands
Cancun
Cancun
I can tell you got a bed cover, the draining hose is right there, relocated the draining hose to a draining hole to avoid water
Cancunbadlands
Cancun
Cancun
And, that would be where? Honestly, I’m not sure, pics?
There's a drain hole at the corner of the bed on each side.
Meeka
Jay
Castlegar B.C. Canada
2024 XLT 2.0 turbo
I ran mine here.
Ignore the water, lol. I had the seal rolled on the rails so the drain was useless at the time of this photo.
Ok, but the water still goes onto the box floor, under the drop in, and rub,rub,rub, rust.
Lugnut
greg
menominee michigan
2023 Maverick XLT
That rust looks like it is laying on top of the paint. It may be in the water coming thru that drain hose.
dmopro
Richardson, TX
MY24 Lariat Hybrid w/SBL
Ford Maverick Rust on / around bed tie downs Left Drain
Ford Maverick Rust on / around bed tie downs Right Drain
Left Drain/Right Drain
ListedGuru
MI
Mercury
Only certain tonneau covers have drain tubes correct? I have a cheap hard tri fold tonneau cover and it doesn't have any drain tubes that I saw at all. Not sure if that's good or bad, lol.
ListedGuru
MI
Mercury
If it sits on top of the bed rails, no tubes. If it has rails that clamp to the inside of the bed rails it should have tubes.
Ok that makes sense as mine sits on top of the bed rails thus no tubes.
DScruggs
Don
Silver Spring MD
2009 F150, 2020 Pacifica Plug-In Hybrid, 2025 Maverick Lariat Hybrid
That rust happened because the person that drilled the holes did not clean up the metal shavings from the drilling process. They also did not properly treat/paint the drilled holes. Most of what you see is tiny steel metal shavings that have rusted.
