My resent trip - All pumped by me - The only variable is the gas pump flow meter accuracy.Yes, I knew a grad student in the early 90's who wrote/logged all odometer readings and gallons-filled data in a little red pocket book. I think he had VW golf or the American version of it...the 4-door Dodge Omni/Plymouth Horizon hatchback.
Ideally, over time, that combined data and mileage would reduce mpg error/variance caused by inconistent pump 'fill to gas pump click-stop,' or any overfilling. But to have the most accurate hand-calucations, it would require YOU filling the vehicle every time. If you loan your car/truck to someone and they top it off, or your spouse drives it and fills it without telling you, your ultimate, hand-calculated numbers will be innacurate.
I'll stick to our Mav's original, never reset, trip tracker fuel economy reading.
Trip Data:
I started with a full tank and ended with a full tank right up to the gas cap and have all the receipts in between. Will add up to see if the dash calculations are correct provided the Gas Stations are honest.
Edit: From Gas Station Receipts - $321.58/67.4606 Gals 2227.3 miles/67.4606 = 33.016 MPG
3.6 MPG Discrepancy in Fords favor.
