smh3550
Shannon
Boise Idaho
2022 Maverick AWD XLT
First post here, but haven’t see too many setups with platforms. I plan to cut the elevate racks to lower it about 3” so the surface of the platform is just above the cab.
The setup is really really sturdy and I love it.
Ford Maverick Rhino Rack Platform + Elevate Rack installed 6D440E98-75A5-4715-8B48-ADD4858C3BC1
Ford Maverick Rhino Rack Platform + Elevate Rack installed 968257C1-E588-48FE-8160-43A471B684E9
Ford Maverick Rhino Rack Platform + Elevate Rack installed 469BC5D4-5614-49DC-968F-7BDE5E479D5E
smh3550
Shannon
Boise Idaho
Also, this is the specific model of platform. It is essentially the very same size as the bed (around the rails).
Rhino Rack Pioneer Platform Rooftop Cargo System 52" x 56" (52111F)
PDM33
Phil
NE Ohio
2022 Maverick Lariat Hybrid
Where do you plan to cut it? The top of the uprights? Looks nice, are you installing a tent on top?
smh3550
Shannon
Boise Idaho
The elevate rack is intended to telescope, so there are actually two tubes for each upright. Need to cut each of them and then re-drill the holes through them. Plan to use a chop saw with a high tooth count blade.
No rooftop tent as we like to set up camp and then tour around. The rack will allow gear on top and soft goods inside the tonneau. Also have some j-racks for kayaks when we want to bring those.
We’ve been using the big truck, but it is overkill most of the time for just two of us. Excited to see how well the maverick works.
Ford Maverick Rhino Rack Platform + Elevate Rack installed 149481AF-AD50-4D36-811B-90E7CE9BF4B6
The Weatherman
Dean
KY
Ford Maverick Rhino Rack Platform + Elevate Rack installed 735E8C19-0711-43E4-88C2-9DD612C95AE3
It makes a super boat totter. Here are two 10’ Whitewater Kayaks and a 14’ Whitewater Canoe.
J_Garn
VA
2012 Ford Edge
How was the installation process with the tonneau and rails?
smh3550
Shannon
Boise Idaho
Install was easy. The tonneau, rails, and elevate rack are all meant to work together
commadorebob
Bookmarked this one. I like it and can see it being handy while camping.
dcs12345
TX
07 Chevy
Is that the X15 cover? If so, how do you like it so far?
glpuckett
ID
2022 Maverick FE Rapid Red 2.5L Hybrid
StillWaiting
Brandyn
St pete
2009 Dodge Challenger SRT8
I agree with cutting it, it will look even better when that’s done
smh3550
Shannon
Boise Idaho
Yes, this is the X15. I have a predecessor to the X15 on my Rebel and love it. This one is very similar, but I really like the look of the canvas instead of black vinyl. Overall we love the X15
smh3550
Shannon
Boise Idaho
glpuckett
ID
Nice work! It looks so much better. We will need to trim even more out of ours to get the platform below the roof. My 'high' setting might be pretty lame.
I think I noted in my final thoughts that I should've cut at least 2", but maybe 3" would work even better....
Remember you will need to cut both inner / outer tubes relatively the same amount; however, I think there is a little leeway on the inner tube. For me it was a tough decision b/c I wanted it low enough (aerodynamics) if I use a RTT, but I needed at least 7 inches clearance for the rolled up BAKX4S. I also wanted the High position to go above my Yakima roof racks.
p/s I used the outer tube cut-off as a drill hole guide for the inner tube.
glpuckett
ID
I should have also mentioned that I was concerned about my visibility out the rear window (didn't want to lose it) and wanted to pay attention to not blocking the break light. That's why I thought 2 inches would've been OK.
Hope this helps
