Is your phone in a case?It’s standard in the 24 Lariat but I don’t use it because my phone gets extremely hot when on the charger pad. The dealer had no idea so I just don’t use it and use the charger cable.
I disagree with the assessment. The wireless charger in my '24 Lariat EB works perfectly fine for charging iPhone 13 Pro Max.OP - don't despair, as the factory wireless charger is useless, anyway. I've owned 2 lariats and even with no case at all, it won't charge enough to even hold the battery % you start with, it just slows the drain a little bit. It's possible that this is better in MY25, but I wouldn't hold my breath - my '22 Bronco with Sync4 has a wireless charging pad that is just as ineffective as my Maverick.
this is especially true if you're using a wireless carplay / android auto dongle. (if you're wired, obviously, you don't need to wirelessly charge.)
if you need wireless charging, I'd search to see what others have done. Also I would not go cheap, there was a guy a few years ago who had a chinese wireless charging pad catch fire and burned his center console - he was lucky it didn't spread and burn the whole interior. (I thought I saved a pic of his fb post, but I can't find it. Trust me, it happened.)
You actually might be the first person to ever say that, the ineffectiveness is pretty well-known.I disagree with the assessment. The wireless charger in my '24 Lariat EB works perfectly fine for charging iPhone 13 Pro Max.
Yes. being in a case will increase the resistance to wireless charging thus making things hotter.Is your phone in a case?
No case and my wife’s the same and a different model. They charge but hotIs your phone in a case?
